Hey guys, I got my X10 smart things shield working, but there is a small problem.
The system works with a custom device type that has preferences, the preferences are used to set the Alpha and Numeric values of the X10 devices.
The arduino sketch then receives that information, and sends the on/off command to the corresponding address.
All of this works just fine. The problem comes in when I add multiple device types with the same network ID. This is needed due to the way it works… since there is only one thing shield receiver.
When I try to add a second device type with the same network ID I get this error…
Oh No! Something Went Wrong! Error 500: Internal Server Error URI /device/save Reference Id a3f97aae-72ce-42c8-bd34-0e6360ea3d4c Date Mon Jan 13 04:01:21 UTC 2014 Class grails.validation.ValidationException Message Validation Error(s) occurred during save(): - Field error in object 'physicalgraph.device.Device' on field 'deviceNetworkId': rejected value [DFA1]; codes [physicalgraph.device.Device.deviceNetworkId.unique.error.physicalgraph.device.Device.deviceNetworkId,physicalgraph.device.Device.deviceNetworkId.unique.error.deviceNetworkId,physicalgraph.device.Device.deviceNetworkId.unique.error.java.lang.String,physicalgraph.device.Device.deviceNetworkId.unique.error,device.deviceNetworkId.unique.error.physicalgraph.device.Device.deviceNetworkId,device.deviceNetworkId.unique.error.deviceNetworkId,device.deviceNetworkId.unique.error.java.lang.String,device.deviceNetworkId.unique.error,physicalgraph.device.Device.deviceNetworkId.unique.physicalgraph.device.Device.deviceNetworkId,physicalgraph.device.Device.deviceNetworkId.unique.deviceNetworkId,physicalgraph.device.Device.deviceNetworkId.unique.java.lang.String,physicalgraph.device.Device.deviceNetworkId.unique,device.deviceNetworkId.unique.physicalgraph.device.Device.deviceNetworkId,device.deviceNetworkId.unique.deviceNetworkId,device.deviceNetworkId.unique.java.lang.String,device.deviceNetworkId.unique,unique.physicalgraph.device.Device.deviceNetworkId,unique.deviceNetworkId,unique.java.lang.String,unique]; arguments [deviceNetworkId,class physicalgraph.device.Device,DFA1]; default message [{0} must be unique]
This appears to be in smart things and is nothing I can do about it?
