Device that will run a motor in forward and reverse
#1
If you put a Smart presents in your mail box how does it work?
(Brian Diehl) #2
I’m not sure I am following the thread title connection to the body…
But, you wouldn’t want to put a presence sensor in your mailbox. All that would do is tell you that your mailbox is present. That’s fine if you have a tendency to have your mailbox stolen, but, it won’t tell you when you get mail.
You’d want to use an open/close sensor like you’d put on a door or window.
Check the link below for any topics that are tagged as project_mailbox
(Robin) #3
I’ll attempt to answer the question in the title rather than the body of your post as the two don’t seem to go together?
The Fibaro Roller Shutter module can run a motor in forward and reverse, it can also auto detect stop limits etc.
(Sid) #4
