Device Handler not receiving HubAction to parse()
I do not know that setting deviceID to ‘:’ is a good idea. This will work for one device, but violates the unique ID requirement for many. Also, current paradigm is NOT to use IP:Port as the DNI as this can change and if it does, it is difficult to rediscover the device.
I use the callback definition (versus parse), then parse in the callback. example, where “command” is a command string, and I use the headers to pass command data. This also works if you have a body to pass. The below are EDITS on running code.
Using headers:
private sendCmdtoServer(command, action){
def headers = [:]
headers.put(“HOST”, “$IP:$PORT”)
headers.put(“tplink-command”, command)
sendHubCommand(new physicalgraph.device.HubAction([
headers: headers],
device.deviceNetworkId,
[callback:cmdResponse]
def cmdResponse(response){
cmdResponse = response.headers[“cmd-response”]
PARSE FUNCTIONS.
Using BODY where command is the sent body and response is the received body.
private sendCmdtoServer(encrCmd, cmdResponse){
sendHubCommand(
body: encrCmd,
headers: [
HOST: “$IP:$PORT”,
[callback: cmdResponse]
def cmdResponse = parseJson(response.body)
PARSE DATA
hope this what you were looking for. The full code for the first example is for a TP-Link bulb, plug, or switch controlled through a PC bridge.
