Device Handler for Aqara Wired Wall Switch
Thanks for this. I notice a few other things:
  1. I’m not seeing the 0x95 and 0x98 keys
  2. I note that the door and window sensors have 0x03 keys which seem to give sensible temperatures, but are not used in the DH. Other devices, such as the wireless switch, also seem to give temperatures, which don’t look correct however.
  3. The wired switch gives a battery level, but always at the maximum.
  4. 0x0a is interesting, as it seems to give a way of building a picture of the zigbee mesh. Looks like zero refers to the hub
  5. I am seeing LQI values of 1 or 2
Hmm, I was just going off of @guyeeba’s driver. What are all the keys that you’re seeing in the check-in messages?
Yes, some devices include temperature readings in the checkin messages that appear correct, but I am not convinced that they are. My impression is that the readings are of the internal (PCB board) temperature, and are not representative of the external air temperature. The only exception to this are the Xiaomi/Aqara Temperature Humidity Sensor models, but those include temperature/humidity(/pressure) readings under different key values.
My guess is that it’s just not used.
Exactly, the ZigBee DNI (Device Network ID) for a SmartThings Hub is always 0x0000, and any other value means that the Xiaomi/Aqara device is connected via mains-powered ZigBee router (repeater) device. This would be helpful in troubleshooting, as the vast majority of ZigBee routers do not allow Xiaomi / Aqara devices to remain connected to the SmartThings’ mesh network, and knowing the DNI can help identify which router device the Xiaomi/Aqara device is connected to.
I assume you’ve already seen this, but just in case not… there are some slight differences between smartthings and hubitat in capabilities, so I don’t think it will run directly in ST, but it might have some more information.
The keys I see are: 0x64,0x65,0x6e,0x6f,0x01,0x03,0x05,0x08,0x0a,0x99,0x9b.
6e and 6f are 0x21 and show similar information to 0x64 and 0x65 except that they are 0x02 when the unwired switch is on, 0x01 when wired.
the final 2 are always zero.
Maybe the keys you are seeing are because there is more than one revision of the no-neutral switches?
Key 0x9b doesn’t show up in other devices I have, but 0x99 is found in the check-in messages of the Aqara Vibration sensor. 0x08 shows up for a number of devices, but it’s use is still a mystery to me.
Thanks to information from veeceeoh & aonghusmor & zigbee2mqtt and based on code from Smartthings ZigBee Switch & Zooz Power Strip Outlet & Diego Schich, I made this DHT for Aqara Switch QBKG12LM.
The way is a little difference. We have 1 main DHT for general information and child for each switch.
  • Main: easy to turn on / off both switches -> easy set automation mode. If we turn on / off each switch separately: main switch will ON when any switch is ON and OFF when both switches are OFF. It also has measurement for voltage, temperature, power & energy for whole QBKG12LM.
  • Child: main will create 2 childs for 2 switches like Zooz Power Strip Outlet.
You can use and modify them for your convenient
Main DHT
 *  for Aqara Switch QBKG12LM
 *  use information from Smartthings ZigBee Switch & Diego Schich & Zooz Power Strip Outlet & Koenkk zigbee2mqtt
 *                     & aonghusmor & veeceeoh
 *  Leza, 10-Aug-2019
metadata {
	definition (name: "Aqara QBKG12LM Main", namespace: "Leza", author: "LPT", vid:"generic-switch-power-energy") {
		capability "Actuator"
		capability "Switch"
		capability "Temperature Measurement"
		capability "Voltage Measurement"
		capability "Power Meter"
		capability "Energy Meter"
		capability "Sensor"
		capability "Configuration"
		capability "Refresh"
		capability "Health Check"
		(1..2).each {
			//attribute "sw${it}Power", "number"
			attribute "sw${it}Switch", "string"
			attribute "sw${it}Name", "string"
			command "sw${it}On"
			command "sw${it}Off"
		fingerprint	profileId: "0104", deviceId: "0051", inClusters: "0000,0001,0002,0003,0004,0005,0006,0010,000A", outClusters: "0019,000A",
					manufacturer: "LUMI", model: "lumi.ctrl_ln2.aq1", deviceJoinName: "Aqara Switch QBKG12LM"
	preferences {
		// Log Debug
		getBoolInput("debugOutput", "Enable Debug Logging", true)
	tiles(scale: 2) {
		multiAttributeTile(name:"switch", type: "lighting", width: 6, height: 4, canChangeIcon: true){
			tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
				attributeState "on", label:'${name}', action:"switch.off", icon:"st.switches.light.on", backgroundColor:"#00A0DC", nextState:"turningOff"
				attributeState "off", label:'${name}', action:"switch.on", icon:"st.switches.light.off", backgroundColor:"#ffffff", nextState:"turningOn"
				attributeState "turningOn", label:'${name}', action:"switch.off", icon:"st.switches.light.on", backgroundColor:"#00A0DC", nextState:"turningOff"
				attributeState "turningOff", label:'${name}', action:"switch.on", icon:"st.switches.light.off", backgroundColor:"#ffffff", nextState:"turningOn"
			tileAttribute("device.lastCheckin", key: "SECONDARY_CONTROL") {
				attributeState("default", label:'Last Update: ${currentValue}')
		valueTile("sw1Name", "device.sw1Name", decoration:"flat", width:5, height: 1) {
			state "default", label:'${currentValue}'
		standardTile("sw1Switch", "device.sw1Switch", width:1, height: 1) {
			state "on", label:'ON', action:"sw1Off", backgroundColor: "#00A0DC"
			state "off", label:'OFF', action:"sw1On", backgroundColor:"#ffffff"
		valueTile("sw2Name", "device.sw2Name", decoration:"flat", width:5, height: 1) {
		standardTile("sw2Switch", "device.sw2Switch", width:1, height: 1) {
			state "on", label:'ON', action:"sw2Off", backgroundColor: "#00A0DC"
			state "off", label:'OFF', action:"sw2On", backgroundColor:"#ffffff"
		valueTile("voltage", "device.voltage", width: 2, height: 2) {
			state "voltage", label:'${currentValue} V', icon:"st.Appliances.appliances17"
		valueTile("temperature", "device.temperature", width: 2, height: 2) {
			state "temperature", label:'${currentValue} °C', icon:"st.Weather.weather2"
		standardTile("refresh", "device.refresh", width: 2, height: 2) {
			state "default", label:'Refresh', action: "refresh", icon:"st.secondary.refresh-icon"
		valueTile("power", "device.power", width: 3, height: 2) {
			state "power", label:'${currentValue} W', icon:"st.Appliances.appliances5"
		valueTile("energy", "device.energy", width: 3, height: 2) {
			state "energy", label:'${currentValue} kWh', icon:"st.Health & Wellness.health7"
		main (["switch"])
		details (detailsTiles)
private getDetailsTiles() {
	def tiles = ["switch"]
	(1..2).each {
		tiles << "sw${it}Name"
		tiles << "sw${it}Switch"
    tiles << "voltage" << "temperature" << "refresh" << "power" << "energy"
	return tiles
private getBoolInput(name, title, defaultVal) {
	input "${name}", "bool",
	title: "${title}?",
	defaultValue: defaultVal,
	required: false
// Globals - Key IDs
private Key_TEMPERATURE()	{ 0x03 }
private Key_RSSI()			{ 0x05 }
private Key_SWITCH_1()		{ 0x64 }
private Key_SWITCH_2()		{ 0x65 }
private Key_ENERGY_METER()	{ 0x95 }
private Key_POWER_METER()	{ 0x98 }
// ZigBee - Data Types
private ZB_Data_BOOLEAN()	{ 0x10 }
private ZB_Data_UINT8()		{ 0x20 }
private ZB_Data_UINT16()	{ 0x21 }
private ZB_Data_UINT64()	{ 0x27 }
private ZB_Data_INT8()		{ 0x28 }
private ZB_Data_FLOAT4()	{ 0x39 }
def installed() {
	// Make sure the switch get created if using the new mobile app.
	runIn(30, createChildDevices)
def updated() {
	if (!isDuplicateCommand(state.lastUpdated, 3000)) {
		state.lastUpdated = new Date().time
		def cmds = []
		if (childDevices?.size() != 2)	cmds += createChildDevices()
		cmds += configure()
		return cmds ? response(cmds) : []
def createChildDevices() {
	(1..2).each { endPoint ->
		if (!findChildByEndPoint(endPoint)) {
			def dni = "${getChildDeviceNetworkId(endPoint)}"
			addChildSwitch(dni, endPoint)
			childUpdated(dni)
private addChildSwitch(dni, endPoint) {
	logDebug "Creating SW${endPoint} Child Device"
	addChildDevice("Leza", "Aqara QBKG12LM Child Switch", dni, null,
			completedSetup: true,
			isComponent: false,
			label: "${device.displayName}-SW${endPoint}",
			componentLabel: "SW ${endPoint}",
			componentName: "SW${endPoint}"
def configure() {
	updateHealthCheckInterval()
private updateHealthCheckInterval() {
	// Device wakes up every 1 hours, this interval allows us to miss one wakeup notification before marking offline
	def minReportingInterval = (1 * 60 * 60)
	if (state.minReportingInterval != minReportingInterval) {
		state.minReportingInterval = minReportingInterval
		logDebug "Configured health checkInterval when updated()"
		// Set the Health Check interval so that it can be skipped twice plus 2 minutes.
		def checkInterval = ((minReportingInterval * 2) + (2 * 60))
		sendEvent(name: "checkInterval", value: checkInterval, displayed: false, data: [protocol: "zigbee", hubHardwareId: device.hub.hardwareID])
def childUpdated(dni) {
	logDebug "childUpdated(${dni})"
	def child = findChildByDeviceNetworkId(dni)
	def endPoint = getEndPoint(dni)
	def nameAttr = "sw${endPoint}Name"
	logDebug "${child.displayName} vs ${device.currentValue(nameAttr)}"
	if (child && "${child.displayName}" != "${device.currentValue(nameAttr)}") {
		sendEvent(name: nameAttr, value: child.displayName, displayed: false)
def ping() {
	logDebug "ping()..."
	return zigbee.onOffRefresh()
def on() {
	logDebug "on()..."
	sw1On()
	sw2On()
def off() {
	logDebug "off()..."
	sw1Off()
	sw2Off()
def sw1On() { childOn(getChildDeviceNetworkId(1)) }
def sw2On() { childOn(getChildDeviceNetworkId(2)) }
def childOn(dni) {
	logDebug "childOn(${dni})..."
	if (endPoint == 1) {
		logDebug "On(${endPoint})..."
		//zigbee.on()
		def actions = [new physicalgraph.device.HubAction("st cmd 0x${device.deviceNetworkId} 0x01 0x0006 0x01 {}")]
		sendHubCommand(actions)
	else if (endPoint == 2) {
		def actions = [new physicalgraph.device.HubAction("st cmd 0x${device.deviceNetworkId} 0x02 0x0006 0x01 {}")]
def sw1Off() { childOff(getChildDeviceNetworkId(1)) }
def sw2Off() { childOff(getChildDeviceNetworkId(2)) }
def childOff(dni) {
	logDebug "childOff(${dni})..."
		logDebug "Off(${endPoint})..."
		def actions = [new physicalgraph.device.HubAction("st cmd 0x${device.deviceNetworkId} 0x01 0x0006 0x00 {}")]
		def actions = [new physicalgraph.device.HubAction("st cmd 0x${device.deviceNetworkId} 0x02 0x0006 0x00 {}")]
def refresh() {
	logDebug "Refresh..."
	def Cmds = zigbee.readAttribute(0x0001, 0x0000, [destEndpoint: 0x01]) +		// voltage
			   zigbee.readAttribute(0x0002, 0x0000, [destEndpoint: 0x01]) +		// temperature
			   zigbee.readAttribute(0x0006, 0x0000, [destEndpoint: 0x01]) +		// switch 1 state
			   zigbee.readAttribute(0x0006, 0x0000, [destEndpoint: 0x02]) +		// switch 2 state
			   zigbee.readAttribute(0x000C, 0x0055, [destEndpoint: 0x03])		// power
	return Cmds
def childRefresh(dni) {
	logDebug "child(${dni})Refresh..."
			   zigbee.readAttribute(0x0006, 0x0000, [destEndpoint: endPoint])	// switch state
	def actions = []
    Cmds?.each {
		actions << new physicalgraph.device.HubAction(it)
	sendHubCommand(actions, 100)
	return []
// Parse incoming device messages to generate events
	logDebug "description is $description"
	def cluster = zigbee.parseDescriptionAsMap(description)
	logDebug "descMap is $cluster"
	if (description?.startsWith("read attr -")) {
		// Switch state
		if ((cluster.clusterInt == 0x0006) && (cluster.attrInt == 0x0000)) {
			if(cluster.endpoint == "01") {
				state.sw1 = (cluster.value == "01" ? "on" : "off")
				executeSendEvent(findChildByEndPoint(1), createEventMap("switch", state.sw1))
				executeSendEvent(null, createEventMap("sw1Switch", state.sw1))
				executeSendEvent(null, createEventMap("switch", ((state.sw1 == "on") || (state.sw2 == "on")) ? "on" : "off"))
        	else if (cluster.endpoint == "02") {
				state.sw2 = (cluster.value == "01" ? "on" : "off")
				executeSendEvent(findChildByEndPoint(2), createEventMap("switch", state.sw2))
				executeSendEvent(null, createEventMap("sw2Switch", state.sw2))
		// Voltage
		else if (cluster.clusterInt == 0x0001 && cluster.attrInt == 0x000) {
			if (cluster.endpoint == "01") {
				def value = (int) (Integer.parseInt(cluster.value, 16) / 10)
				executeSendEvent(null, createEventMap("voltage", value, null, "V"))
				executeSendEvent(findChildByEndPoint(1), createEventMap("voltage", value, null, "V"))
				executeSendEvent(findChildByEndPoint(2), createEventMap("voltage", value, null, "V"))
		// Temperature
		else if (cluster.clusterInt == 0x0002 && cluster.attrInt == 0x000) {
				def value = Integer.parseInt(cluster.value, 16)
				if (value > 127)	value = value - 256
				executeSendEvent(null, createEventMap("temperature", value, null, "C"))
				executeSendEvent(findChildByEndPoint(1), createEventMap("temperature", value, null, "C"))
				executeSendEvent(findChildByEndPoint(2), createEventMap("temperature", value, null, "C"))
		// Power meter
		else if ((cluster.clusterInt == 0x000C) && (cluster.attrInt == 0x0055)) {
			if (cluster.endpoint == "03") {
				def value = Float.intBitsToFloat(Long.parseLong(cluster.value, 16).intValue())
				executeSendEvent(null, createEventMap("power", roundTwoPlaces(value), null, "W"))
	if (description?.startsWith("catchall:")) {
		if ((cluster.clusterInt == 0x0000) && (cluster.attrInt == 0xFF01)) {
			Map key = [:]
			int i = 4
			int j
			// get keys
			while (i < cluster.data.size()) {
				// save start index
				j = i
				// get key type
				key.type = Integer.parseInt(cluster.data[i], 16)
				if      (key.type == Key_TEMPERATURE())		key.name = "temperature"
				else if (key.type == Key_RSSI())			key.name = "RSSI"
				else if (key.type == Key_SWITCH_1())		key.name = "switch1"
				else if (key.type == Key_SWITCH_2())		key.name = "switch2"
				else if (key.type == Key_ENERGY_METER())	key.name = "energy"
				else if (key.type == Key_POWER_METER())		key.name = "power"
				else										key.name = "unknown (" + cluster.data[i] + ")"
				// get key value
				i++
				key.datatype = Integer.parseInt(cluster.data[i++], 16)
				if (key.datatype == ZB_Data_BOOLEAN()) {
					key.value = ((cluster.data[i] == "01") ? "on" : "off")
				else if (key.datatype == ZB_Data_UINT8()) {
					key.value = Integer.parseInt(cluster.data[i], 16)
				else if (key.datatype == ZB_Data_UINT16()) {
					key.value = Integer.parseInt(cluster.data[i+1] + cluster.data[i], 16)
					i += 1
				else if (key.datatype == ZB_Data_UINT64()) {
					key.value = Long.parseLong(cluster.data[i+7] + cluster.data[i+6] + cluster.data[i+5] + cluster.data[i+4] +
											   cluster.data[i+3] + cluster.data[i+2] + cluster.data[i+1] + cluster.data[i], 16)
					i += 7
				else if (key.datatype == ZB_Data_INT8()) {
					if (key.value > 127) {
						key.value = key.value - 256
				else if (key.datatype == ZB_Data_FLOAT4()) {
					key.value = Float.intBitsToFloat(Long.parseLong(cluster.data[i+3] + cluster.data[i+2] +
																	cluster.data[i+1] + cluster.data[i], 16).intValue())
					i += 3
				logDebug "index: $j, key: $key.name, value: $key.value"
				// send event
				if (key.type == Key_TEMPERATURE()) {
					executeSendEvent(null, createEventMap("temperature", key.value, null, "C"))
					executeSendEvent(findChildByEndPoint(1), createEventMap("temperature", key.value, null, "C"))
					executeSendEvent(findChildByEndPoint(2), createEventMap("temperature", key.value, null, "C"))
				else if (key.type == Key_SWITCH_1()) {
					state.sw1 = key.value
				else if (key.type == Key_SWITCH_2()) {
					state.sw2 = key.value
				else if (key.type == Key_ENERGY_METER()) {
					executeSendEvent(null, createEventMap("energy", roundTwoPlaces(key.value), null, "kWh"))
				else if (key.type == Key_POWER_METER()) {
					executeSendEvent(null, createEventMap("power", roundTwoPlaces(key.value), null, "W"))
				i++
	// send event for heartbeat
	def now = new Date().format("dd-MM-yyyy HH:mm:ss", location.timeZone)
	sendEvent(name: "lastCheckin", value: now, displayed: false)
	executeSendEvent(findChildByEndPoint(1), createEventMap("lastCheckin", now))
	executeSendEvent(findChildByEndPoint(2), createEventMap("lastCheckin", now))
private executeSendEvent(child, evt) {
	if (evt.displayed == null)	evt.displayed = (getAttrVal(evt.name, child) != evt.value)
	if (evt) {
		if (child) {
			if (evt.descriptionText) {
				evt.descriptionText = evt.descriptionText.replace(device.displayName, child.displayName)
            logDebug "${evt}"
			child.sendEvent(evt)
		else {
			logDebug "${evt}"
            sendEvent(evt)
private createEventMap(name, value, displayed=null, unit=null) {
	def eventMap = [
		value: value,
		displayed: displayed,
		isStateChange: true,
		descriptionText: "${device.displayName} - ${name} is ${value}"
	if (unit) {
		eventMap.unit = unit
		eventMap.descriptionText = "${eventMap.descriptionText} ${unit}"
	return eventMap
private getAttrVal(attrName, child=null) {
	try {
		if (child) {
			return child?.currentValue("${attrName}")
		else {
			return device?.currentValue("${attrName}")
	catch (ex) {
		//logTrace "$ex"
		return null
private findChildByEndPoint(endPoint) {
	return findChildByDeviceNetworkId(dni)
private findChildByDeviceNetworkId(dni) {
	return childDevices?.find { it.deviceNetworkId == dni }
private getEndPoint(childDeviceNetworkId) {
	return safeToInt("${childDeviceNetworkId}".reverse().take(1))
private getChildDeviceNetworkId(endPoint) {
	return "${device.deviceNetworkId}-SW${endPoint}"
private safeToInt(val, defaultVal=0) {
	return "${val}"?.isInteger() ? "${val}".toInteger() : defaultVal
private safeToDec(val, defaultVal=0) {
	return "${val}"?.isBigDecimal() ? "${val}".toBigDecimal() : defaultVal
private roundTwoPlaces(val) {
	return Math.round(safeToDec(val) * 100) / 100
private isDuplicateCommand(lastExecuted, allowedMil) {
	!lastExecuted ? false : (lastExecuted + allowedMil > new Date().time)
private logDebug(msg) {
	if (settings?.debugOutput != false) {
		log.debug "$msg"
Child DHT
 *  for Aqara Switch QBKG12LM - Child Switch
 *  modify code from Smartthings ZigBee Switch & Diego Schich & Zooz Power Strip Outlet
 *  Leza, 10-Aug-2019
metadata {
	definition (name: "Aqara QBKG12LM Child Switch", namespace: "Leza", author: "LPT", vid:"generic-switch-power-energy") {
		capability "Switch"
		capability "Sensor"
    simulator { }
	tiles(scale: 2) {
		main (["switch"])
		details(["switch", "voltage", "temperature", "refresh"])
def installed() {}
def updated() {
	parent.childUpdated(device.deviceNetworkId)
def on() {
	parent.childOn(device.deviceNetworkId)
def off() {
	parent.childOff(device.deviceNetworkId)
def refresh() {
	parent.childRefresh(device.deviceNetworkId)
© 2019 SmartThings, Inc. All Rights Reserved. Terms of Use | Privacy Policy
SmartThings; SmartApps®; Physical Graph; Hello, Home; and Hello, Smart Home are all trademarks of the SmartThings, Inc.
