Of course, here it is.
Use at your own risk, but seems to be working fine for me.
Add new device handler and pair the Develco Smart plugs as usual.
* Modified version of Smartthings zigbee-metering-plug from smartthings repository for Develco Smart Plug Mini
* Copyright 2019 SmartThings
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
import physicalgraph.zigbee.zcl.DataType
metadata {
definition (name: "Develco Smart Plug Mini", namespace: "Develco", author: "Balder", ocfDeviceType: "oic.d.smartplug", mnmn: "SmartThings", vid: "generic-switch-power-energy") {
capability "Energy Meter"
capability "Power Meter"
capability "Actuator"
capability "Switch"
capability "Refresh"
capability "Health Check"
capability "Sensor"
capability "Configuration"
fingerprint profileId: "0104", manufacturer: "Develco Products A/S", model: "SPLZB-131", deviceJoinName: "Develco Outlet" // Develco smart plug mini, raw description: 02 0104 0051 10 09 0000 0702 0003 0009 0B04 0006 0004 0005 0002 05 0000 0019 000A 0003 0406
fingerprint profileId: "0104", manufacturer: "Develco Products A/S", model: "SPLZB-132", deviceJoinName: "Develco Outlet" // Develco smart plug mini, raw description: 02 0104 0051 10 09 0000 0702 0003 0009 0B04 0006 0004 0005 0002 05 0000 0019 000A 0003 0406
fingerprint profileId: "0104", manufacturer: "Develco Products A/S", model: "SPLZB-134", deviceJoinName: "Develco Outlet" // Develco smart plug mini, raw description: 02 0104 0051 10 09 0000 0702 0003 0009 0B04 0006 0004 0005 0002 05 0000 0019 000A 0003 0406
fingerprint profileId: "0104", manufacturer: "Develco Products A/S", model: "SPLZB-137", deviceJoinName: "Develco Outlet" // Develco smart plug mini, raw description: 02 0104 0051 10 09 0000 0702 0003 0009 0B04 0006 0004 0005 0002 05 0000 0019 000A 0003 0406
fingerprint profileId: "0104", manufacturer: "Develco Products A/S", model: "SMRZB-143", deviceJoinName: "Develco Outlet" // Develco smart cable, raw description: 02 0104 0051 10 09 0000 0702 0003 0009 0B04 0006 0004 0005 0002 05 0000 0019 000A 0003 0406
tiles(scale: 2){
multiAttributeTile(name:"switch", type: "generic", width: 6, height: 4, canChangeIcon: true){
tileAttribute("device.switch", key: "PRIMARY_CONTROL") {
attributeState("on", label: '${name}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#00a0dc")
attributeState("off", label: '${name}', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff")
valueTile("power", "device.power", decoration: "flat", width: 2, height: 2) {
state "default", label:'${currentValue} W'
valueTile("energy", "device.energy", decoration: "flat", width: 2, height: 2) {
state "default", label:'${currentValue} kWh'
standardTile("refresh", "device.power", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
standardTile("reset", "device.energy", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "default", label:'reset kWh', action:"reset"
main(["switch"])
details(["switch","power","energy","refresh","reset"])
def getATTRIBUTE_READING_INFO_SET() { 0x0000 }
def getATTRIBUTE_HISTORICAL_CONSUMPTION() { 0x0400 }
log.debug "description is $description"
def event = zigbee.getEvent(description)
def descMap = zigbee.parseDescriptionAsMap(description)
if (event) {
log.info "event enter:$event"
if (event.name == "switch" && !descMap.isClusterSpecific && descMap.commandInt == 0x0B) {
log.info "Ignoring default response with desc map: $descMap"
return [:]
} else if (event.name== "power") {
event.value = event.value/getPowerDiv()
event.unit = "W"
} else if (event.name== "energy") {
event.value = event.value/getEnergyDiv()
event.unit = "kWh"
log.info "event outer:$event"
sendEvent(event)
} else {
List result = []
log.debug "Desc Map: $descMap"
List attrData = [[clusterInt: descMap.clusterInt ,attrInt: descMap.attrInt, value: descMap.value]]
descMap.additionalAttrs.each {
attrData << [clusterInt: descMap.clusterInt, attrInt: it.attrInt, value: it.value]
attrData.each {
def map = [:]
if (it.value && it.clusterInt == zigbee.SIMPLE_METERING_CLUSTER && it.attrInt == ATTRIBUTE_HISTORICAL_CONSUMPTION) {
log.debug "power"
map.name = "power"
map.value = zigbee.convertHexToInt(it.value)/getPowerDiv()
map.unit = "W"
else if (it.value && it.clusterInt == zigbee.SIMPLE_METERING_CLUSTER && it.attrInt == ATTRIBUTE_READING_INFO_SET) {
log.debug "energy"
map.name = "energy"
map.value = zigbee.convertHexToInt(it.value)/getEnergyDiv()
map.unit = "kWh"
if (map) {
result << createEvent(map)
log.debug "Parse returned $map"
return result
def resetEnergyMeter() {
log.debug "resetEnergyMeter: not implemented"
* PING is used by Device-Watch in attempt to reach the Device
def ping() {
return refresh()
def refresh() {
log.debug "refresh"
zigbee.onOffRefresh() +
zigbee.electricMeasurementPowerRefresh() +
zigbee.readAttribute(zigbee.SIMPLE_METERING_CLUSTER, ATTRIBUTE_READING_INFO_SET)
def configure() {
// this device will send instantaneous demand and current summation delivered every 1 minute
sendEvent(name: "checkInterval", value: 2 * 60 + 10 * 60, displayed: false, data: [protocol: "zigbee", hubHardwareId: device.hub.hardwareID])
log.debug "Configuring Reporting"
return refresh() +
zigbee.onOffConfig() +
zigbee.configureReporting(zigbee.SIMPLE_METERING_CLUSTER, ATTRIBUTE_READING_INFO_SET, DataType.UINT48, 1, 600, 1) +
zigbee.electricMeasurementPowerConfig(1, 600, 1) +
zigbee.simpleMeteringPowerConfig()
private int getEnergyDiv() {
isDevelcoOutlet() ? 1000 : 100
private boolean isDevelcoOutlet() {
device.getDataValue("manufacturer") == "Develco Products A/S"
