I have the Schlage FE599NX CAM 619 and am finding that the battery is draining fast. Noticed that the lock is being polled every minute (or more). Is there a way to decrease the poll time to every hour or more (if a change is not detected)?
It will poll every 2 minutes if the lock DTH’s codes and the lock manager app’s codes do not match. This will always happen for unconfigured codes so be sure to not have any users left unconfigured. If you only need 2 codes set the user number to 2.
This is fixed in the new lock code release by ethayer.
Good catch. I thought I deleted both the user and the code, but looks like just the code. BETA looks good as well - will give that a try.
No luck - deleted unused users and still polling every 2 minutes (including resetting code usage). 4 slots and 4 users and I am still seeing consistent polling. Will move to the BETA to see if this helps. Thanks.
Hopefully last one on this. Discovered that I had two users that were not enabled in the user settings (they were set up, had a code, but the enabled switch was off). Apparently when they are not enabled, it will poll for each user every 2 minutes (I was getting two poll events every 2 minutes). I deleted the two users that were not enabled and it is not polling any more (at least after 15 minutes).
For those using ZigBee locks, I have released a newer version of my Universal Enhanced Zigbee Lock with Lock Codes. Upgrade at your soonest convenience.
I’m having issues with routines running. I have it set to run a I’m home routine in the app but setting it for each individual as well as the global setting it does nothing. It won’t run the routine when I unlock with the keypad even though it States unlocked with slot…
Any ideas?
I just reverted back to the regular Z-wave lock device type for my Schlage Connect lock. The custom handler just isn’t working for some reason, and 'tis NOT the season to be messing with that particular functionality… I can live with entering/deleting codes manually at the lock for the time being. I can’t live with being unable to get into my house lol
hello again guys
i’m stuck - i have the 3rd kwikset 910 lock installed and it appears to work fine manually, but codes cannot be programmed by the smart app nor can i check the status of the lock nor can i get any push alerts except for door locked - all other alerts including unlocked are not working. any advice please? thanks!
brad
You don’t have any manually programmed codes on the lock do you? That what was causing everything to fall apart for me.
coz: yes i have one manually created code - i read earlier in the thread that you can’t get digital codes to work until after you have created one manual code first. is this not correct? thanks!
Does anyone now if this works with Kwikset 916? Was thinking about purchasing one of these from Home Depot. Thanks!
Both the ZigBee and Z-Wave versions of the Kwikset 916 are officially supported.
Brad,
I’m not sure where you read that. But, I had a code manually programmed into the lock and had to delete the code manually from the lock and then re-add the code from the Smart Things app and everything is now working as it should.
hi coz
i was told you had to break the seal and enter a manual code to make space for the digital codes. please tell me how to remove a manual code as the instruction sheet that came with the lock only tells me how to add a code, thanks!
brad
You have your “Master programming code” still? Because if you lost that, you are out of luck, you won’t be able to do anything with that lock at all.
hi
brand new lock, has no master code assigned. i did a full reset and the manual code was still working.
brad
Great App! I have a weird issue that doesn’t seem to be a normal issue. My wife and my iPhone 7s will not allow us to enable user codes. Sliding enable and then clicking done only works about 1 out of 100 times. Our iPad works perfectly consistently. I have restarted hub, phones, logged out and back in of the ST app. Nothing seems to fix this. Any help is appreciated.
How do you tell which is the newest Schlage connect model? The “newest model” on Amazon doesn’t match up with what’s on the Schlage site.
Amazon: BE468-2K (Says first listed on Amazon April 2016)
(New Model) Schlage Connect Century Touchscreen Deadbolt with Z-wave Technology and Extra Key BE468-2K (Satin Nickel) https://www.amazon.com/dp/B01EKA88ZE/ref=cm_sw_r_cp_apa_kUczybZ0M63V4
Schlage: BE469NX CEN 619
Schlage Connect™ Touchscreen Deadbolt with alarm with Century trim BE469NX CEN 619
http://www.schlage.com/en/home/products/BE469NXCENFFF.html
Answer my own question - I called Schlage and they said that the 469 is the newer version, and that the info on Amazon (that the 468-2K is a newer model) is incorrect.
I don’t have any other way to verify, but the facts that the 469 is also the model they have on their web site, and that it has a higher number in the sequence, does seem to be consistent w/the 469 being the newer model.
Just ordered one (used-very good) from Amazon for $139, so looking forward to using the combination of the auto-lock feature and our “Good Night” routine to stop accidentally leaving our front door unlocked all the time.
