v0.2.0bd.20170612 - BETA M2 - More bug fixes, work started on capture/restore, DO NOT USE them yet
Do not attempt to use Capture (it doesn’t work, hub may explode lol)
@blinduvula you need to update to this first, you’re probably getting an error as it is - when a date/time cannot be converted, it returns null instead of 0 and the subtraction fails.
@ady624 Error noticed, but you had it fixed before I had a chance to ask.
webCoRE updated and the error is gone, but it looks like there are some odd things happening. Process seems to be:
Step on mat
Light turns green
Light turns off
Wait 5 min
Light turns back on as green
Tracing it through, it looks like maybe the order isn’t quite right and I might need to throw in separate If statements for the light being on and off (or at least that’s how I’d go about it in CoRE).
Thanks again for the help! Just realized I’ve been talking to the mastermind behind this and I now feel a little silly.
naturally its time to use them … how come it doesn’t work right?
from the UI for capture, there is an option to save to global or local store but didn’t see a named stored. do you plan to make capture/restore from a named store an option?
Try swapping the set color and turn on between them. That works for me, but the turn on may bring it on to the wrong color for a second there. Click on the turn on and in that dialog you can move it up and down by clicking on the gray bars showing all the other tasks in the action.
You can reorder tasks from inside the task editor dialog. The dialog lists all the tasks before and after the current one, just click on the one you want to move away and make room
Here’s what I was thinking of. First piston manages some lights that have different behavior in 3 different modes. Modes are:
Evening
Movie
Party
Mode switches from Evening to Party to Movie to Party to Evening. Let’s look at the captures:
Mode switches from Evening to Party - Capture 1
Mode switches from Party to Movie - Capture 2
Mode switches back from Movie to Party - Restore Capture 2
Mode switches back from Party to Evening - Restore Capture 1.
To do this with a global store and a local store, I could use the global store in step 1 and the local store in step 2 and back it out from there in steps 3 and 4.
Second piston, manages another set of lights based on settings of the lights controlled by the first piston when in Evening or Party mode. This piston will have access to the lights as they were set in the Evening mode because these are in the global store but not the lights as they were set in the Party mode as these are in the local store of the first piston.
Hence the ask for named stores. Happy to answer other questions.
I’m having issues getting the Flash command to work with my Hue Lights since last week. I tested this out on a extremely simple piston but the flash works fine on my other bulbs but not on my Hue Color bulbs like it used to. I’m using tmleafs version of Hub B Smart so not sure if this is a webCoRE issue or issue with this custom Smartapp/Device Handler: [UPDATED 4/19/17] Hue B Smart (Smart and FAST Hue Lighting)
WebCore Logs:
6/12/2017, 10:24:33 PM +618ms
+1ms ╔Received event [Front Door Sensor].contact = closed with a delay of 782ms
+219ms ║RunTime Analysis CS > 21ms > PS > 98ms > PE > 100ms > CE
+230ms ║Runtime (32305 bytes) successfully initialized in 98ms (v0.2.0bd.20170612) (228ms)
+232ms ║╔Execution stage started
+253ms ║║Comparison closed is open = false (3ms)
+256ms ║║Cancelling condition #4's schedules...
+258ms ║║Condition #4 evaluated false (14ms)
+260ms ║║Cancelling condition #1's schedules...
+261ms ║║Condition group #1 evaluated false (state changed) (19ms)
+266ms ║╚Execution stage complete. (34ms)
+275ms ╚Event processed successfully (274ms)
6/12/2017, 10:24:32 PM +926ms
+3ms ╔Received event [Front Door Sensor].contact = open with a delay of 1098ms
+337ms ║RunTime Analysis CS > 125ms > PS > 111ms > PE > 101ms > CE
+381ms ║Runtime (32307 bytes) successfully initialized in 111ms (v0.2.0bd.20170612) (376ms)
+382ms ║╔Execution stage started
+403ms ║║Comparison open is open = true (3ms)
+406ms ║║Condition #4 evaluated true (12ms)
+407ms ║║Condition group #1 evaluated true (state did not change) (14ms)
+411ms ║║Cancelling statement #2's schedules...
+453ms ║║Executed physical command [Living Room Hue Light (by Front Door)].flash([2000, 2000, 5, null]) (26ms)
+455ms ║║Executed [Living Room Hue Light (by Front Door)].flash (28ms)
+459ms ║╚Execution stage complete. (77ms)
+471ms ╚Event processed successfully (471ms)
Well ady624, I thought I had my virtual switch issue resolved with your suggestion to use switch is on instead of switch changes to on. But this morning at sunrise, things didn’t go as planned.
On line #27, Dimmer 7 is my virtual switch. I also had to turn on the Always subscribe option for that line.
On line #42, sunrise is a trigger that should result in the two lights turning off. But since the virtual switch was in the ON position, it resulted in both lights turning on at sunrise (which was not my intention).
Do you have any other suggestions on how I can fix this piston?
I modified the piston so instead of trying to turn the lights off at sunrise, it should try turn them off at “368 minutes before sunrise” (or 11:29pm). I turned on FULL logs, turned both lights off, left the virtual switch on, and then waited for 11:29pm. The piston ran and my lights turned on instead of staying off. Here are the logs:
6/12/2017 11:28:59 PM +91ms
+1ms
╔Received event [My Home].time = 1497328140000 with a delay of -910ms
+160ms
║RunTime Analysis CS > 22ms > PS > 84ms > PE > 54ms > CE
+174ms
║Runtime (33953 bytes) successfully initialized in 84ms (v0.2.0bd.20170612) (170ms)
+177ms
+223ms
║║Comparison :b0877b20e8cfd015291ae908f0c75159: is_not :12b020925300bb83870c0f79587caf29: = true (12ms)
+227ms
║║Condition #1 evaluated true (33ms)
+230ms
║║Condition group #null evaluated true (state did not change) (36ms)
+265ms
║║Comparison off is off = true (5ms)
+272ms
║║Comparison off is off = true (4ms)
+277ms
║║Cancelling condition #16’s schedules…
+279ms
║║Condition #16 evaluated true (39ms)
+314ms
║║Comparison 1497328139372 happens_daily_at 1497317220000 = false (1ms)
+317ms
║║Condition #17 evaluated false (35ms)
+319ms
║║Cancelling statement #17’s schedules…
+329ms
║║Requesting time schedule wake up at Tue, Jun 13 2017 @ 8:12:00 PM CDT
+333ms
║║Condition group #15 evaluated false (state did not change) (94ms)
+350ms
║║Comparison on is on = true (3ms)
+352ms
║║Condition #19 evaluated true (16ms)
+354ms
║║Condition group #18 evaluated true (state did not change) (18ms)
+355ms
║║Condition group #12 evaluated true (state did not change) (120ms)
+360ms
║║Cancelling statement #13’s schedules…
+430ms
║║Executed physical command [Bedroom Light].setLevel([20]) (61ms)
+431ms
║║Executed [Bedroom Light].setLevel (63ms)
+495ms
║║Executed physical command [Upstairs Hallway Light].setLevel([20]) (62ms)
+496ms
║║Executed [Upstairs Hallway Light].setLevel (64ms)
+522ms
║║Comparison turningOn is on = false (4ms)
+525ms
║║Cancelling condition #24’s schedules…
+527ms
║║Condition #24 evaluated false (22ms)
+528ms
║║Condition group #23 evaluated false (state did not change) (25ms)
+530ms
║║Condition group #20 evaluated false (state did not change) (27ms)
+540ms
║╚Execution stage complete. (364ms)
+542ms
║Setting up scheduled job for Tue, Jun 13 2017 @ 8:12:00 PM CDT (in 74580.368s)
+559ms
╚Event processed successfully (558ms)
