Do you guys know how can I fix this problem?
On old SmartThings Classic app the power consumption shows right (1700 Wh) but if I switch to new Connect app it shows 1.7MWh which itās wrong, the scale itās wrong.It should have been 1.7KWh.
It should also be noted that the Energy Meter capability defines its units as Wh, kWh or mWh. Unfortunately the app UI has a habit of folding the first character to uppercase which makes a mess of SI units, in this case making a difference of nine orders of magnitude.
I believe the default units are supposed to be kWh which would appear to be correct.
It seems like the unit has been set to mWh (or MWh) somewhere on the assumption the value would get magically scaled.
@Gutheinz : already done that for the official integration, but no response, no support.It not even works properly, because the official one does not even measure the power, it only has an ON/OFF switch.
@orangebucket yes, it should have been kWhā¦I donāt have code skills, so i cannot modify myself the DTHā¦
Oh hang on, this is Daveās handler isnāt it? It looks like it is pumping out energy usage in Wh without a unit. The new app would probably see that as kWh and perhaps I did it a disservice and it can scale the units automatically and is displaying MWh.
Glad you got it fixed. Remember, it is deprecated and will not carry over to when the classic app and IDE die away! I will maintain the current state for errors, so I will update the code when I have a break from my Hubitat and life requirements.
Thanks to everyone for using my Integration. It was a pleasure and I am sorry to see it come to an end!
Additionally, since I do not have the skills, etc. if anyone wants to carry this to the future, the GitHub repository is mine and OPEN SOURCE. You have permission to use as you see fit. I also have a lot of node.js tools (old node version) that I can share; including the old manual install that used a stand-alone server. Those can be made available (not all are on GitHub. I have node.js tools like a UPNP discovery tool that allows you to see the UPNP devices on your LAN, a tool to rapidly list Kasa devices, and tools to test the commands I discovered during the investigation process.
I just bought a Kasa HS 300 smart plug. Iād like to get the power use info into Smartthings but Iāve read all of the posts and it still is not clear to me if I can do this now. I have the new Smartthings app. I can figure out how to add the device handler, but not clear to me if that will work adding at this point.
If it is, what order do I do this? Do I first add DH, then do integration of TP link to Smartthings?
Be sure to read through the documentation folder on the GitHub site. Dave has great detailed instructions there that should point you in the right direction.
Keep in mind that the official integration of TP-Link to Smartthings can exist parallel, but it is separate from the SmartApp.
Both the SmartApp and the Device Handler (DH) need to be installed through the IDE, and if both the official TP-Link integration and the SmartApp are installed, each device will appear 2 times.
However, as the HS300 is a multi-socket device, not sure if the DH in its current form will correctly report the HS300 device capabilities. Making this another reason to push TP-Link to update their integration into Smartthings with the missing Energy Monitoring (EM) capabilities.
First, I am no longer using smartThings; however, the driver/service managers are still available. The HS-300 is in the code; including the EM function. HOWEVER, I have not (can not) update this code to worke with the new Appās interface to include Energy Functions.
[/quote]
Yes, I have been reading this information. It just is not clear to me if with the end of Classic app if this will work with new Smartthings app. I donāt add DHās often, so it will cost me a day of my life to do it Iād like to know if there is a pot of gold at the end.[quote=āDerakkon, post:402, topic:142507, full:trueā]
Thanks Ernie. Are you using the new Smartthings app with the Device Handlers and getting energy use information? Iām not clear on whether any of this will work now that Classic Smartthings is gone.
I have already contacted both TP Link and Samsung about the need for this upgrade.
I am currently on Hubitat and have similar code there. If anyone knows of explicit fixes for the DTH to help integration into the new API, please let me know.
Itās very easy to get an incorrect device handler, or at least it was for me. It was in the Deprecated list, but not on this table in the documentation. I found it by sifting through conversations to find Dave Gutheinzās update for the HS 300 Device Handler. āTP Link EM Multi-Plug.groovyā is the one you need.
