[DEPRECATED] EchoSistant Evolved ~ Amazon Echo's Only Assistant with Robust Scheduling and Flexible Reporting
Update Alert!
I have pushed an update to the Notification-Add on to align it with recent enhancements that have been done on the RemindR app. The two apps are now identical and can be used from within ES, or as a stand alone app. The update requires an update to the EchoSistant main app.
This update is not required. You may continue to use the current versions of your apps. This is the first major update in a series leading up to the release of EchoSistant Version 5, which is scheduled for June 30th (if testing goes smoothly).
