I just sent you a new version to your gmail address. First, save your public and private keys from Automatic, and you just need to copy and paste the code from MyAutomaticServiceMgr. The rest of the code has not changed.
The reason for the exception is that your nickname (in the Automatic Mobile App) is not populated. I made the change today to use the model name instead and it works.
Today, I made some changes to MonitorAutomaticCar in order to send notifications to Ask Alexa.
This way, the summary of real-time events and the details of them (if detailedNotif is true) will be sent to Ask Alexa as a message. You can then query the message queue by asking Alexa to “play messages.”
Hello, Thanks for developing this Integration and App.
I understand from this thread that there is some kind of presence detection available with this integration.
I have the new Automatic PRO
Will this work for the below Use Case?
Detect presence when approaching near Home/Garage Door. Note: The engine is NOT shut off at this point so the trip is not completed yet.
Hi, do you want to migrate My Automatic device from a Lite V1 to a Pro? If so, you’re talking about replacing your existing ST device with another one.
Like any ST devices, you should first unselect the device from any smartapps where it is used.
After doing this, you need to press “remove” in MyAutomaticServiceMgr. This will delete the device from the SmartThings graph.
You can then add the new PRO device using MyAutomaticServiceMgr. You need to follow the installation steps provided.
Today, now that the HTMLTile is better supported by all iOS AND Android devices, I added a graph “DistanceVsCost” at the bottom of MyAutomatic Device. It will report your vehicle’s distance and cost for the past week.
These are nice reports! I’m new to gravestreams. I’m not sure how to get reports for multiple streams. In any case, I’ll figure it out. This is exactly the kind of data I want. Wireless Sensor Tags gives you something like this. I want the thermostat runtimes in the mix. This looks like it will do what I want. Just need to learn to use grovestreams. . …
Thanks. I’ve been reading through their docs. I’ve had your groveStreams app running for a couple days now. I’m gradually getting some data uploaded. . . .
edit: The tutorial was helpful. Grovestreams is very powerful! It’s so nice to be able to do something useful with all this data.
My 3G Automatic Pro arrives today and I’m looking at purchasing your device/app for use with my smartthings platform, but one thing I’m specifically hoping for is to use it as a presence sensor (so every time my wife arrives home it opens the garage door, disarms SHM, etc) without using her phone. She has a Windows Phone. So, that said, using the 3G Automatic it shouldn’t require a phone, do you support the 3G? I assume you connect directly to automatic via their servers so it shouldn’t matter if the data gets to their servers, phone or 3G? Just wanted some clarification before I pull the trigger.
