I’m having problems installing the MyAutomaticServiceMgr. OAuth is enabled. I got through to the step where I should be able to select the Automatic Device. I’m getting an “unexpected error” on that screen. I can see in the logs that my device was detected
getAutomaticDevices>found vehicleId=C_6dab753f779711a0,name=null,make=Toyota,model=Highlander.
I also see the final debug statement printed from the AutomaticDeviceList function:
list p: [name:deviceList, title:Select Your vehicle(s), nextPage:otherSettings, previousPage:null, content:AutomaticDeviceList, install:false, refreshInterval:-1, sections:[[input:[[description:Tap to choose, multiple:true, title:, required:true, name:AutomaticDevices, type:enum, metadata…list p: [name:deviceList, title:Select Your vehicle(s), nextPage:otherSettings, previousPage:null, content:AutomaticDeviceList, install:false, refreshInterval:-1, sections:[[input:[[description:Tap to choose, multiple:true, title:, required:true, name:AutomaticDevices, type:enum, metadata:[values:[952b7424-bdee-4f36-bc58-0800fead20a8.null.C_6dab753f779711a0:null]]]], body:[[title:, description:Tap below to see the list of Automatic connected vehicles available under your Automatic account and select the ones you want to connect to SmartThings., element:paragraph, type:paragraph, required:false, multiple:false], [element:input, description:Tap to choose, multiple:true, title:, required:true, name:AutomaticDevices, type:enum, options:[952b7424-bdee-4f36-bc58-0800fead20a8.null.C_6dab753f779711a0:null]]], hideable:false, hidden:false]], popToAncestor:null, onUpdate:null]
