I got it. I thought I still had to tell smartthings to turn the thermostat
on before I can set it. It is working. What ever you did to speed it up
worked very well. That was something my wife before was how long it would
take to process a command.
YeahâŠfrom a programmers point of view I was calling variables sometimes 12 times with one call, and for those I reduced those down to once per call. Then, for anything macro related (specifically voice reports), I moved the âtranslationâ matrix to the Lambda code. I get the impression the Lambda code, function for function, runs faster than the same code in SmartThings. There are swings in timing based on internet latency and load, but I believe all the âlittle thingsâ add up after a while.
Anyway, glad it is working for you.
Is there a way to use Amazon Echo as a remote speaker like Sonos to make announcements such as âDoor was left openâ?
Unfortunately noâŠthis is probably one of the more generally asked questions, and the answer is:
âThe Echo, as it is designed currently, cannot react to switches opening or other actions within SmartThings. She will do things for you, but only at your direction and at the time of the requestâŠâ
So she will NOT ever speak up unless she is spoken toâŠ
Good suggestions that I put this in the documentation: http://thingsthataresmart.wiki/index.php?title=Ask_Alexa#Limitations
This would be great if we could route Ask Alexa general Sonos HTTP uPnP commands to Sonos through SmartThings HTTP. I have followed the instructions with rgracianoâs echo-sonos which integrates the Amazon Echo with Sonos. All I have to say is âAlexa Ask SonosâŠâ but I would love to be able to say âAlexa Ask SmartThings to play|group|turn up|down volumeâŠâ
How Echo-Sonos works
- When you say the command to Alexa, it triggers the Alexa skill with invocation name Sonos.
- The Alexa skill calls a web service running on AWS Lambda, passing it the preset name (ârockâ in the example).
- Lambda then fires an HTTP request to a node.js server running node-sonos-http-api on your local network.
- node-sonos-http-api interprets the command and relays to Sonos over your local network (designated open port on Firewall).
Ask Alexa has the ability (through the ST integration) to do the whole play, up, down, etc commands now. Coming soon is the ability to set up memory slots to allow you to choose the music you want to playâŠ
Hi MichaelS, thanks for the awesome update! Is the ability to add a password requirement in there for voice macroâs as well? I canât seem to find it for voice macros.
Thanks again!
Not yetâŠfrom a technical perspective I was struggling with this as I use the numeric component (which is also used with any delays you may put in) so you would have to choose between one or another. However, I think I worked around this issue and am going to attempt to get it working in probably the version after next.
Awesome, thank you again very much MichaelS!
No problemâŠwas the right thing to do to give this option universally instead of just on certain items. However, in doing this I think I came up with some rather creative ways to implement this.
One other question. Is there a way to trigger a beep during a delay? For example, on my âI am leavingâ macro I have it set to a one minute delay. What would be nice is to be able to tell it to send a âbeepâ command to my zipato multi-sound siren to let me wife know the delay is going and then it stop beeping once it arms. Is there a way to do that now?
@MichaelS just wanted to say great implementation of the personalities Tried out Courtesy mode last night, canât wait to try out the others. Do you think we would be able to control the personality based on the current mode? Maybe something we can do via CoRE?
[Bug Report]
A status setting under Power Voice Reports is not updated even though it has already been configured:
That is an interesting requestâŠso, HOME mode might be Normal, but Party mode might be âSnarkyâ? HmmmmâŠLet me get all of the major personality types in there and then see if it would make sense. I know from a technical perspective it would certainly be possible.
Ironically, I was working on Snarky todayâŠthe monotone voice doesnât lend itself well to snarkyâŠwhich is interesting just from a language perspectiveâŠit isnât just the words and toneâŠlike a terminator saying âhahahahââŠwithout the inflection it isnât much but just words then. However, I did do some interesting thingsâŠlike have her change your name to knucklehead or Silly randomly, or say âFineâŠI will just go work on the Skynet project thenâ
Fun stuff, and your suggestions keep it interesting.
Good CatchâŠI should have caught this when you suggested the other, similar, issue before. I corrected this and it is now going to be in 2.1.1.
Let me know if you find any others.
Right now there is no feedback that comes from the Alexa or an other deviceâŠI like your suggestion about the sirenâŠare there other apps that can get it to âbeepâ as I could copy that functionality. I did see the need to notification about scheduled tasks, so there is an option in the current version to put a notification into the Events log you see on your SmartThings mobile app.
Also, I was successful in allowing a password on Core, Control, Group and Device Group (door and lock) macros. It would now be easy to set this up as well on voice reporting macros or device groups for thermostats, but see no real advantage to thatâŠThoughts?
I donât see any advantage to requiring a password on reports, but that said just because I donât see a use case doesnât mean no one else does If itâs not hard to do and doesnât have a negative impact I wouldnât see any reason why not to allow the option there.
If possible we could maybe have a core piston handle the beep? Have it run independent and just set it for the same amount of time as the delay? Of course I would have to somehow trigger that piston in the macro, then add delay, then execute a second action which I donât think is possible currently.
What would be REALLY cool for people (but Iâm guessing is probably not possible) is to have an option to have Alexa produce a sound during the delay period. This would let people have a delay audio notification even if they donât have a device like I do that would support it. Just let the echo/dot handle the audio feedback.
If you have connected speakers you could create a piston and do tts, having your speaker countdown.
