I deleted my Honeywell ZWave thermostat. When I re-added it, all values are null. I can turn on the fan and set to hot/cold, but the temp setpoints are all null. Any thoughts?
Wait a while. The tables need to be refreshed.
How long is a while? It’s been about 3 hours now. Is that typical?
I would sleep on it, before I worry…
Ok will do. Don’t remember having it take this long when I added it a year ago.
No change overnight. Rebooted the tstat and the hub.
Since temperature isn’t showing up, I can’t change setpoints due to null errors.
Anyone have any idea why the hub isn’t seeing all values from the tstat?
Ok, that sounds like a bad inclusion. Did you try running a replace? Or even a general exclusion and then inclusion? I have two of these and didn’t experience these issue with either of them.
Also, what do you mean by rebooting t-stat. Did you cut the power to it, sometimes if my tstat goes unresponsive, power cycling helps.
Yeah I have 2 as well - both strong for a year until I removed one to test something. Now I can’t add it back with all values and control.
I did try a repair and it said the device is healthy.
In the graph API, my 1st (and working tstat) shows these operating states:
temperature: 71.0 F
heatingSetpoint: 63.0 F
coolingSetpoint: 78.0 F
thermostatSetpoint: 78.0 F
thermostatMode: cool
thermostatFanMode: fanAuto
thermostatOperatingState: idle
thermostatFanState: idle
currentState: in A/C Mode and is idle
currentMode: cool
currentfanMode: Auto Mode```
but my 2nd one only shows these:
```thermostatOperatingState: idle
currentState: Idle
currentMode: cool
I could try to remove it, reboot both things, then re-include it.
Just odd that ST only picked up half of the device.
What a pain! That really sounds like a bad inclusion. I would try to run a general exclusion and then inclusion. Are you using a custom handler for your other tstat?
Oh, do not just remove it! that leaves orphans behind. You must exclude it properly. And then include it.
Yeah they both have a custom handler. However, when I added it, it received the default handler and it was null with the default too.
I’ll try a re-inclusion this evening
