When my Kwikset deadbolt is unlocked it tells my alarm to turn off, via a routine. This does not happen quick enough, therefore my door contact sensor triggers the alarm before the deadbolt turns off the alarm. Is there a way to delay the door contact sensor trigger a couple of seconds? I am hoping for a simpler solution than the SHM Delay smart app.
If you are using the new app, the SHM in the new app has an entry delay option. No custom code required. But know that that is a completely different feature than the one in the classic app even though they have the same name.
You can use both apps at the same time, but alerts set in the classic app can only be dismissed from the classic app and the same for alerts set in the new app.
