Guys,
I’m trying to predefine that all switch type will be selected for an app I’m coding.
I would like to know whether the defaultValue can work. And if so, how I can make it work
Guys,
You can’t use defaultValue for a device you want to select. Only the user can select devices during the installation of the app. This is a security mechanism.
You lock it down to a single devicetype
http://docs.smartthings.com/en/latest/smartapp-developers-guide/preferences-and-settings.html#input
capability.capabilityName can be swaped for device.deviceTypeName
If you need a example check out PlantLink-DirectMonitor.groovy or ThinkingCleanerer.groovy
Thanks for the advice, the issue is that not all switches are using the same device type (have 3 different ones)!
Thanks!!
That’s the beauty of Capabilities. They are Device Type independent. All light switches, outlets, and light bulbs support a capability of “Switch”, for example. So a smart app simply needs to look for devices that support the switch capability.
