# Data usage smart things hub?
**URL:** <https://community.smartthings.com/t/data-usage-smart-things-hub/72613>\
**Category:** Projects & Stories\
**Created:** [January 8, 2017, 6:36pm UTC](https://community.smartthings.com/t/data-usage-smart-things-hub/72613 "2017-01-08T18:36:45Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![Opo2k](https://yyz2.discourse-cdn.com/smartthings/user_avatar/community.smartthings.com/opo2k/32/45696_2.png) [@Opo2k](https://community.smartthings.com/u/Opo2k)\
**Post date:** [January 8, 2017, 6:36pm UTC](https://community.smartthings.com/t/data-usage-smart-things-hub/72613/1 "2017-01-08T18:36:45Z")
</div>
How much data does the hub or connected devices use or send ? I am looking to set up ST hub on a smartphone with cellular wifi tethering (unused line on family plan )
**Author:** ![cmj](https://avatars.discourse-cdn.com/v4/letter/c/258eb7/32.png) [@cmj](https://community.smartthings.com/u/cmj)\
**Post date:** [January 9, 2017, 2:28am UTC](https://community.smartthings.com/t/data-usage-smart-things-hub/72613/2 "2017-01-09T02:28:00Z")
</div>
There are a couple posts that answer your question:
> [@Smartthing high data usage](https://community.smartthings.com/t/smartthing-high-data-usage/53918):
> Hello All, I’m new to the SmartThings community and v2 hub. I just built a house in the boonies and was required to get a data plan from Verizon for installed home internet. In other words, I’m limited on data now. We just moved in the house on Sunday. I have the hub hooked up and only running one thing. A Schlage front door lock. I also have 2 Ecobee thermostats connected. I am getting a crazy high data drain/usage from the hub. About 150mb per 30 minutes. When I disconnect the hub from my router, the drain stops. This seems very high and I don’t think it’s right. Does anyone have any ideas on what could be causing the high data usage and how to stop it? I am planning to run the entire house off the hub and Amazon Echo, but I’m not sure I’ll be able to if I can’t get the data usage u…
> [@SmartThings Data Usage!](https://community.smartthings.com/t/smartthings-data-usage/35868):
> What kind of data usage would a SmartThings Hub consume for a basic set up of 8 -10 things. LIke contact sensors, moisture sensors, thermostat and door lock? What will be the best way of assessing this? Any ideas?
Adding a chart that shows my data usage over the past 30 days.
 ![](https://global.discourse-cdn.com/smartthings/original/3X/c/c/ccecc08050ce4340ea7a47a8d836562da179da60.png)
**Author:** ![oldcomputerwiz](https://avatars.discourse-cdn.com/v4/letter/o/c77e96/32.png) [@oldcomputerwiz](https://community.smartthings.com/u/oldcomputerwiz)\
**Post date:** [January 9, 2017, 4:09pm UTC](https://community.smartthings.com/t/data-usage-smart-things-hub/72613/3 "2017-01-09T16:09:17Z")
</div>
I did some programming using CoRE last month, here is my Wi-Fi data usage. This DOES NOT include any data from my wife’s phone or any IDE usage. This is only Wi-Fi usage on my mobile phone. This is pretty typical usage for me as I tend to tinker with my rules.
 ![](https://global.discourse-cdn.com/smartthings/original/3X/f/2/f289bf38c07c9f1b4981e54ec949713a646232fb.png)
