@625alex. Can you complete the Security pin integration for the SmatTiles? I really want to setup a tablet with the dashboard in order to Arm/Disarm the Smart Alarm via the Hello Home frazes and I canβt do that yet because the dashboard does not securely lock. Also, can you add a feature for the dashboard to auto load when the Android loads up, almost like a custom load. Just a thought.
If you are using Android you can just use the lock screen that come with the tablet, thats what I do. Also as far as I know there is no way to auto load on startup unless you are running a custom rom. I am very new to Android and am still learning so I could be wrong, if there is a way I would love it too
Actually you are incorrect. I am using an IP Webcam on my old Samsung (Not Rooted) as a baby cam. It has an option to force the device to load the baby cam on restart. This is very useful if your device runs out of power or crashes and reloads.
Also. thanksβ¦for the thought.
Thanks, my experience shows
Since SmartTiles only runs thru a web browser wouldnβt the browser need to have the autostart feature and not SmartTiles?
On Android, you can use Tasker to launch an app or run an activity on boot.
- Create a profile and use the Event context > System > Device Boot.
- Inside the profile, you would add a Task with the Action: Net > Browse URL to open your SmartTiles page.
Awesome, thanks for that!
Iβve used this on my install
You can set it as the homescreen, and disable the lock screen to make it available at reboot. It does a few other nice lock down stuff, and Iβve bought the pro version so my panel shows a nice slideshow of pictures until you touch it.
i use this too, it has a lot of flexibility as far as configuration goes
I know the battery is a custom icon, but I cannot figure out how to change the color of the icon. For me it is stuck white or the hex code equivalent.
Also I have two custom tiles that pull audio levels and air pressure. I am trying to figure out how to add an icon to the left footer of the tile, like the other standard tiles. When I look at the page on the app to change the device order of my tiles I see the icons and background color I added for my items, but when I look on the tile there is just the current state of the device. I tried looking at the new luminosity and acceleration tiles for clues in the app and support files, but I feel I am missing some small detail to get it to work.
The battery icon is missing from the Font Awesome library, so itβs hard coded to white image. This is why you are not able to change itβs color. I will be addressing it in the maintenance release 5.4.
You need to add icon reference in this area of SmartTiles javascript file. Then, you will need to host your modified version of the javascript.
Altenatively, you can change the tile rendering in SmartTiles.groovy to add your icons there.
Since audio level and air pressure capabilities technically donβt exist within ST universe, I canβt really code for these capabilities.
Sorry, Iβm a bit new to ST. I canβt seem to find the code to modify icons since Iβve installed SmartTiles via the web app. Is it possible to modify?
Also, will the icon changes persist through updates?
Doing the Install Now will not let you customize, yet. You have to install via the IDE, this should get you going
Upcoming release of SmartTiles will expose the custom CSS, including installations via βInstall Nowβ option. The CSS changes will be persistent between updates.
Is there away in custom css to have the color change base on the temperature in the tile?
Yes, your CSS selector should be something like this:
.temperature[data-value='20Β°'] .icon {color: red}
You have to add one selector per temperature value.
@swindmiller β¦ each degree needs a color or it will default to your original color. I just did this it took a little while. The color I used is a test, but youβre welcome to copy and paste if you wish.
.temperature[data-value=β105Β°β] .icon {color: #8B0000}
.temperature[data-value=β104Β°β] .icon {color: #8B0000}
.temperature[data-value=β103Β°β] .icon {color: #8B0000}
.temperature[data-value=β102Β°β] .icon {color: #8B0000}
.temperature[data-value=β101Β°β] .icon {color: #8B0000}
.temperature[data-value=β100Β°β] .icon {color: #8B0000}
.temperature[data-value=β99Β°β] .icon {color: #FF0000}
.temperature[data-value=β98Β°β] .icon {color: #FF0000}
.temperature[data-value=β97Β°β] .icon {color: #FF0000}
.temperature[data-value=β96Β°β] .icon {color: #FF0000}
.temperature[data-value=β95Β°β] .icon {color: #FF0000}
.temperature[data-value=β94Β°β] .icon {color: #FF4500}
.temperature[data-value=β93Β°β] .icon {color: #FF4500}
.temperature[data-value=β92Β°β] .icon {color: #FF4500}
.temperature[data-value=β91Β°β] .icon {color: #FF4500}
.temperature[data-value=β90Β°β] .icon {color: #FF4500}
.temperature[data-value=β89Β°β] .icon {color: #D2691E}
.temperature[data-value=β88Β°β] .icon {color: #D2691E}
.temperature[data-value=β87Β°β] .icon {color: #D2691E}
.temperature[data-value=β86Β°β] .icon {color: #D2691E}
.temperature[data-value=β85Β°β] .icon {color: #D2691E}
.temperature[data-value=β84Β°β] .icon {color: #D2691E}
.temperature[data-value=β83Β°β] .icon {color: #FF8C00}
.temperature[data-value=β82Β°β] .icon {color: #FF8C00}
.temperature[data-value=β81Β°β] .icon {color: #FF8C00}
.temperature[data-value=β80Β°β] .icon {color: #FF8C00}
.temperature[data-value=β79Β°β] .icon {color: #FF8C00}
.temperature[data-value=β78Β°β] .icon {color: #FF8C00}
.temperature[data-value=β77Β°β] .icon {color: #FFD700}
.temperature[data-value=β76Β°β] .icon {color: #FFD700}
.temperature[data-value=β75Β°β] .icon {color: #FFD700}
.temperature[data-value=β74Β°β] .icon {color: #FFD700}
.temperature[data-value=β73Β°β] .icon {color: #FFD700}
.temperature[data-value=β72Β°β] .icon {color: #FFD700}
.temperature[data-value=β71Β°β] .icon {color: #FFD700}
.temperature[data-value=β70Β°β] .icon {color: #FFD700}
.temperature[data-value=β69Β°β] .icon {color: #FFD700}
.temperature[data-value=β68Β°β] .icon {color: #6B8E23}
.temperature[data-value=β67Β°β] .icon {color: #6B8E23}
.temperature[data-value=β66Β°β] .icon {color: #6B8E23}
.temperature[data-value=β65Β°β] .icon {color: #6B8E23}
.temperature[data-value=β64Β°β] .icon {color: #6B8E23}
.temperature[data-value=β63Β°β] .icon {color: #6B8E23}
.temperature[data-value=β62Β°β] .icon {color: #6B8E23}
.temperature[data-value=β61Β°β] .icon {color: #6B8E23}
.temperature[data-value=β60Β°β] .icon {color: #6B8E23}
.temperature[data-value=β59Β°β] .icon {color: #6B8E23}
.temperature[data-value=β58Β°β] .icon {color: #00FF7F}
.temperature[data-value=β57Β°β] .icon {color: #00FF7F}
.temperature[data-value=β56Β°β] .icon {color: #00FF7F}
.temperature[data-value=β55Β°β] .icon {color: #00FF7F}
.temperature[data-value=β54Β°β] .icon {color: #00FF7F}
.temperature[data-value=β53Β°β] .icon {color: #00FF7F}
.temperature[data-value=β52Β°β] .icon {color: #00FF7F}
.temperature[data-value=β51Β°β] .icon {color: #00FF7F}
.temperature[data-value=β50Β°β] .icon {color: #00FF7F}
.temperature[data-value=β49Β°β] .icon {color: #66CDAA}
.temperature[data-value=β48Β°β] .icon {color: #66CDAA}
.temperature[data-value=β47Β°β] .icon {color: #66CDAA}
.temperature[data-value=β46Β°β] .icon {color: #66CDAA}
.temperature[data-value=β45Β°β] .icon {color: #66CDAA}
.temperature[data-value=β44Β°β] .icon {color: #66CDAA}
.temperature[data-value=β43Β°β] .icon {color: #66CDAA}
.temperature[data-value=β42Β°β] .icon {color: #66CDAA}
.temperature[data-value=β41Β°β] .icon {color: #66CDAA}
.temperature[data-value=β40Β°β] .icon {color: #00FFFF}
.temperature[data-value=β39Β°β] .icon {color: #00FFFF}
.temperature[data-value=β38Β°β] .icon {color: #00FFFF}
.temperature[data-value=β37Β°β] .icon {color: #00FFFF}
.temperature[data-value=β36Β°β] .icon {color: #00FFFF}
.temperature[data-value=β35Β°β] .icon {color: #00FFFF}
.temperature[data-value=β34Β°β] .icon {color: #00FFFF}
.temperature[data-value=β33Β°β] .icon {color: #00FFFF}
.temperature[data-value=β32Β°β] .icon {color: #00FFFF}
.temperature[data-value=β31Β°β] .icon {color: #00FFFF}
.temperature[data-value=β30Β°β] .icon {color: #00FFFF}
.temperature[data-value=β29Β°β] .icon {color: #00FFFF}
.temperature[data-value=β28Β°β] .icon {color: #00FFFF}
.temperature[data-value=β27Β°β] .icon {color: #00FFFF}
.temperature[data-value=β26Β°β] .icon {color: #00FFFF}
.temperature[data-value=β25Β°β] .icon {color: #00FFFF}
Sweetβ¦thanks so much!!
