Dashboard missing from Home screen after updating to the new SmartThings UI
After updating to the new SmartThings UI, I have encountered an issue with the new Dashboard on the Home screen.
In Edit Home, the Dashboard is present and enabled. When I tap Edit on the Dashboard, I can also see and enable items such as Temperature, Lights, Curtain Motors, Humidity, and Smart Hubs.
However, after saving and returning to the Home screen, the entire Dashboard card is missing. It does not appear at all.
Before the UI update, information such as Lights and other home status items was displayed normally on the Home screen. As I understand it, these items have now been moved into the new Dashboard card, but the new Dashboard itself is not being displayed for me.
I have already tried:
Removing and re-adding the Dashboard
Changing the enabled items in the Dashboard
Restarting SmartThings
Uninstalling and reinstalling the SmartThings app
Checking SmartThings Now, which is enabled
Checking my Location membership — I am the Owner, not a restricted member
None of these solved the problem.
There is also another issue that may be related:
The SmartThings home-screen widget is also missing the status/shortcut buttons that used to show information such as Lights and Offline Devices. These items were previously available, but disappeared after the new UI update as well.
So I am wondering whether the Dashboard/status information for my Location was not migrated correctly after the UI update, or whether this is a bug in the new version.
Has anyone else experienced the same issue, especially where both the in-app Dashboard and the status items in the home-screen widget are missing?
Any suggestions would be appreciated.
Not helpful, I know, but my home tab had all the same objects arranged just as they had been before the update. Both on my Pixel Tablet and Pixel 10 Pro phone. Tiny font and on the tablet smaller tiles but everything was there except for the tile for offline devices in the dashboard.
When you edited the home tab and chose delete all and disable the SmartThings now tile… did you save your settings at this point? Then return and add one or two items back and save to see if those showed up? If successful, go back and add more.
