Custom Files with Speaker Notify with Sound
(Rick Meyers) #1
Has any gotten custom mp3 hosted on dropbox or google drive to work with Speaker Notify with Sound
I have the app installed and working but only the built in (and amazon hosted) mp3 work.
I have tried the “dl=1” flag and the “raw=1” flags on dropbox but neither work.
Any advice would be greatly appreciated, thanks
I do believe I edited the code correctly (adding action type at the top, and the file path to the case statement down below)
#2
Is the file “public” in your drop-box? You have to make sure the link is correct too. You don’t want to bring up the file on drop-box you need to link to the direct download. You might also want to look at this. I’ve never used it but some have to use custom sounds.
(Anthony S.) #3
in order to use dropbox you will need to manually modify the share link…
Here’s the original link: https://www.dropbox.com/s/b7i2xasdae9s2yvwm/manifest.json?dl=0
Now here is the required url: https://dl.dropboxusercontent.com/s/b7i2xasdae9s2yvwm/manifest.json
(Rick Meyers) #4
That worked perfectly.
Thank you so much!
