Yes. As far as ST is concerned it is a different handler even if the code is identical.
Brilliant!
Thanks once again, Graham.
Anyone else notice that in iOS, in detailView
, the status
control label
field doesnât render {{attribute.value}}
for new capabilities. Seems to be working on Android, on iOS it just displays {{attribute.value}} on the screen instead displaying the attribute value.
UPDATE: it looks like the iOS server is having caching issues and ignoring updates to presentations despite a new VID. It eventually caught up the next day.
yes, you need to set the property âtypeâ in the alternatives as active
or inactive
in the capability presentation. If you donât include it, the default value for all the alternatives is active
In the sample below Iâm using Smart Lock as device Type.
Note: Up to now, it works fine on Android devices. I already reported that the icon is not changing correctly on iOS devices, so our engineering team is working on this fix.
@nayelyz @cscheiene
The issue when a demical number donât showing up on dashboard tile still remains on iOS.
Same thing with automations. They donât showing up for custom capabilities.
Is there any update regarding there issues?
Can you report these on the engineering team too?
Also is there a way to change between active/inactive icons, based on attribute value?
Etc:
if attr.value is < 100 -> inactive
if attr.value >=100 -> active
This issue is already reported, thanks for your feedback.
Automations are not available for display on the mobile app yet; once they are supported, your configuration will be shown.
Up to now, itâs possible only using the alternatives. You could create a custom capability to change the icon and change its value when the other capability meets the condition (<100 or =<100). I can think of using Rules to do so, hereâs an example:
Is there a way to change in the device presentation the label of a capability ?
For example âmomentaryâ capability has a default âMomentaryâ as a label (i18n.label). Is it possible to change it in the detailView of the device?
I tried to play with âvaluesâ under detailView but I got back errorsâŠ
The âvaluesâ property at the device configuration is used to set the supported values of a capability, such as ThermostatOperatingState in your device, or to change the range of the numeric capabilities.
Up to now, the presentation (label, display type, etc.) of a stock capability cannot be modified.
thank you. So is the only way to have a different label is to duplicate the stock capability into a custom one?
Youâre right, they might look different though, eg. âBatteryâ has a slider
display type and in the app, a color bar appears to represent it because it uses customized UI, a feature not available for custom capabilities yet.
I tried to create a dynamic label that takes the value of the âunitâ property.
for ex., :
"detailView": [
"label": "{{txstat.unit}}",
"displayType": "state",
"state": {
"label": "{{txstat.value}}"
but the label shows as txtstat.unit despite setting the"unit" with SendEvent to a value.
Is it possible to have a dynamic label (the headline not the value)?
Up to now, only the State
display type label is dynamic, the unit can be included there too. The cardâs label is a simple String.
Hello - my understanding is that right now the Developer Workspace does not give you the option of using ccâs created by others when you are defining direct connect devices. Is this under consideration for the future or will we always have to create any ccâs under our own namespace? Once the IDE goes away, the Developer Workspace needs to allow specifying ccâs created by others.
That rather depends on the distribution model for community developed handlers.
I wouldnât use someone elseâs custom capability in my own integration. They could change or delete it and potentially break every device using it.
Yes I can see it could be problematic but on the other hand we want to share projects with others that will probably include custom devices. If you have to tell people they have to go learn cli and recreate the devices themselves⊠well forget that!
Yes, but we canât project the current custom DTH model forwards. It sucks now, so why repeat it? Even if a similar code sharing model was used, why would you share the code but not the source of the capabilities?
Both would be ideal, but hey Iâd be happy with the minimum of at least being able to find & select othersâ custom capabilities in the Developer Workspace.
But I certainly understand all the focus right now is getting the heritage groovy-stuff ready for whatever transition is going to happen, so Iâll just have to be patientâŠ
We donât even know what is replacing the ide for hub connected devices.
And basically most custom DTHs act as hub connected devices.
So for now weâre just speculating.
