Thanks edleno - I have created both the presentation and capabilities. What I’m trying to do now is create the device config so I can get a VID. Does that sound right?
Could you post your mypresentationfile.yaml
Yea, the json version is the 2nd part of my original post.
The two jsons you posted are a capability and a capability presentation. Ed’s comment is correct - a device-config has a different structure.
I see - and I can’t generate a default one?
yeah, @mwilkie. I agree with @philh30 and @edleno. Also, in Edge, you don’t need to create the device-config manually unless you want to apply a special configuration (change the default range, enums, etc.) because it is generated automatically.
To generate a default one, you must have the device installed to get the device profile ID, once you get that, you can use this command to generate a file with the default config
smartthings presentation:device-config:generate deviceProfileID [-j or -y] -o=mydeviceConfig.json
Then, you make the corresponding changes and use the command smartthings presentation:device-config:create ...
to save it.
Assuming the default device-config based on your profile doesn’t match your needs, here are the steps:
Get the profile ID for your device:
smartthings devices <device #>
Then generate the default device-config using the profile:
smartthings presentation:device-config:generate <profile ID> -o mydeviceconfig.json
Edit that file, then upload it using the create
command.
Ah - I bet that it! I’ll try later today (my device wasn’t installed) Thanks!
Ok, after making sure my lan device was installed, tried to generate my default config but unfortunately am still getting a 500.
smartthings presentation:device-config:generate 691a324b-d931-439d-b5b2-3636d58901f8 -j -o=out.json
Error: Request failed with status code 500:
{"requestId":"FEF26715-7D25-4E32-8013-7AD218B70F99","error":{"code":"UnexpectedError","message":"Error generating
device configuration","details":[]}}
To be clear though, my end goal is to get the VID so I can add it to my profile and see the new capability show up. Is that right?
Given this, how can I find the VID?
Thanks all!
OK…looks like I forgot to update my capabilities definition in the lua. I did this, and things are behaving now more as expected.
Thanks all for your help
Once you install the device, you can get the device list and there’s a property called presentationId
AKA VID
Having the VID you can do other things:
- Query its configuration
smartthings presentation VID [-j or -y]
- Get the original device-config used to create it
smartthings presentation:device-config 1491a1e5-b77e-3e8b-8fad-49ed566a5ca8 [-j or -y]
Good that you got it all working. If you wanted to go WITHOUT the VID (use the Edge default device-config) then just remove the metadata tags in the yaml file in the /profiles directory.
