For what it’s worth, I have a few CREE bulbs and my outdoor 2 by garage doors occasionally give me similar grief (wrong status, slow response) I was pretty much resolved it’s due to distance from hub, since my indoor bulbs which are closer, never skip a beat & I would venture to say are my most reliable Lights vs OSRAMS.
FYI, I tried some OSRAM bulbs by the garages outside, and they couldn’t get any response, so for me the CREE’s had better reach.
i have not tried to exclude the offending Cree bulb yet but i were to, i am not sure how to proceed in excluding it.
the offending Cree bulb is powered by a single/regular/standard OFF/ON switch along with another Cree bulb.
if i were to do the exclusion process, i.e. General Device exlusion >> Remove >> the turn switch on or off, would’nt this exclude both Cree bulbs as they are both powered by the same switch? then would mean id have to re-pair two Cree bulbs instead of one?
Take out the bulb & complete the process in a controlled location OR just loosen the other bulb enough to disconnect from power while you’re disassociating/associating the offending bulb.
