@johnconstantelo I am trying to use your My MIMOlite - Garage Car Door v3 code. When I try to create a new device type “from code” and paste in the code form Github I get the error:
Org.springframework.dao.DuplicateKeyException: a different object with the same identifier value was already associated with the session: [physicalgraph.device.CapabilityDeviceType#physicalgraph.device.CapabilityDeviceType : (unsaved)]; nested exception is org.hibernate.NonUniqueObjectException: a different object with the same identifier value was already associated with the session: [physicalgraph.device.CapabilityDeviceType#physicalgraph.device.CapabilityDeviceType : (unsaved)]
I’m not sure what to look for. I used your v2 device type code and it worked fine. Can you offer any suggestions what I might need to change?
I saw this come in yesterday thorugh support. That device has a “capability garageDoorControl” which cannot compile because that capability doesn’t exist. So remove that and it will work.
The other garage door control capability is the correct one and will compile.
interestingly enough, I had this trouble yesterday as well… Though I had actually had this exact code in a device type and removed it yesterday. - I did find, however that after removing the different garage door capabilities, I could create the device type… and then I updated the device type with the capabilities that I removed… and it saved OK. Weirdness!!
Yeah, it did. But if @slagle says it’s not needed, then I’m still confused, as the exact same device type code did not throw the error when I set it up initially last month. (long story, but I removed the existing device type I had yesterday during some troubleshooting)
