I have an android wear device. I can create a button in IFTTT, but how do I expose my linear garage control to IFTTT so I can open/close with the button?
You need:
To see the device in ST.
Give access to IFTTT via ST to that device… (there is an option to select which devices IFTTT can access)
It should be enough…
because the linear garage door opener isnt a switch or a lock, IFTTT doesn’t allow it to be manipulated a by an button. I therefore, used a customer device handler witch turns it into a switch. That appears to be working. I wish you could change the icon of the button. It shows a smart things icon, which isn’t helpful.
