Hi,
Is there a way to create a on/off switch button or a Routine in Smartthing to trigger a IFTTT button or Applet?
Thanks in advance.
Hi,
Thanks in advance.
You can create a virtual switch and then use it as the “THIS” or the “THAT” in an IFTTT applet.
But I’m not sure I understand what you’re trying to do. Can you elaborate?
I have a IFTTT button to turn on the Nest fan. Currently, I cannot find an easy to create a button or a switch just simply turn on the Nest fan for 15 min. Someone built a template just for that, very handy and simple. I just want to create a switch so I can further customize automation with a momentary switch or some sort. Not sure if I explain clearly here.
Have you looked into any of the community developed solutions that integrate Nest with SmartThings directly?
