Hi All, I have a Z Wave Rocker and a Z wave plug in dimmer module. both seem to work as they please. this has happened recently.
I have firmware 000.032.00010 so I believe it to be the latest.
Nothing else has moved in the house and the other Z Wave devices work without issue. I don’t want to buy new switches but will if I need to.
Any thoughts? leave it alone and see if it resolves itself?
have you tried running z-wave repair? any errors if you have? or tried unplugging the plug and pulling the air-gap on the switch? check IDE to look at the routing info if needed.
I forget the brand of rocker switch, but the plugin dimmer came with the Smartthings V2 Hub when I got in 2016 or 2015 (I forget now)… I unplugged the module, I flipped the bypass on the wall switch… now last night they worked without issue… I will keep an eye on them… I have other Z wave devices that never skipped a beat
As for Z wave repair… how do I go about doing that?
