I have several CoRE pistons that are executing when they shouldn’t tonight, and when they do execute, they are repeating over and over. Anyone else having issues? I have a couple of pistons that set a couple of lights in the bathroom to low levels when mode changes to night, wait a few seconds, then turn off. Most nights, they do exactly that…set to 1 or 2%, wait X seconds, then shut off. Tonight i ran good night routine and now it’s like a rave in the master bathroom, I have 3 different lights that keep turning on and off in 5 second intervals. Wife is upset, just stormed off to sleep in the guest room where there are no smart switches installed.
Here’s one of my pistons, keeps repeating over and over. I have several like it, they are all doing the same…
Logs…
Tagging @ady624. Unplugging hub and going to bed.
It’s called a circular reference - your but if condition is too general and you should start using execute on piston state change only.
Made a change in 15e to fix a bug affecting latching pistons. NOT ST’s fault this time.
Hmmm ok sorry for the false alarm. I was really hoping I could blame the angry wife on someone else
So the secondary if block will be executed if any of the conditions in either of the if blocks changes? Am I understanding that correctly? My previous understanding was that each if block would only be evaluated if a condition in that particular if block changed, which is why I had such general conditions. And that is from the 15e change that…I…uh…requested? I hate it when I am one of those annoying end users who is responsible for his own problems
