is anybody using Bose Soundtouch 10 or 20 to speak or play messages created in webcore?
Thanks that fixed the weather reporting The 2nd example I posted still is not responding
@tommyincville @eric182.
Not trying to be padantic, but this is the CoRE thread not the webCoRE thread.
You might to post your queries there.
Thanks, That the second time of done this. At least with the first time I discovered webCoRE
Alright, Iâm frustrated, I understand everything about pistons logically and how they work, and have set up a few of them except I have seen examples that show things like IF âTrigger happens every 30 minutesâ but I canât figure out how to actually set that up, please help.
I am currently trying to do this? Did you ever figure it out?
Timer needs to be a top-level entry, so If Timer is a bad thing. Click where you add a new top-level statement (If, Action) and Timer should be your third option.
You can say something like âevery 30 minutes, if X is open, send an SMSâ. However, the pistons Iâve written so far havenât needed the timer â I use triggers (like X opening) and then use waits within the actions. (Though you might need to enable advanced instructions and add a while to achieve the âevery 30 minutesâ behavior that way.)
Please somebody save my sanity, I feel like complete idiot
Installed shower door sensor to control the bathroom fan ON and OFF with delay 5 minutes when the door opens. Thought that it will be easy but it ainât so .
Created one piston to turn the fan ON, thatâs working great
Second piston for delayed OFF will not wait those 5 min but it will turn the fan OFF immediately when the door opens
Can you please tell me where is my problem?
My other plan was also override the bath motion sensor if shower door is closed to keep the light on but wouldnât even dear to do that now
Put the wait 5 mins and the turn off in the same action.
If you edit the piston and look at the wait 5 mins, scroll down and you will see add a task.
Click on it a d put in turn off.
Then delete yohr existing turn off.
Att the moment both tasks will execute at the same time.
OMG itâs working !
THANK YOU THANK YOU THANK YOU!
Should have asked sooner
Ha Ha.
Well done.
As you have probably realised now you can put a group of tasks into one action and they will run sequentially.
Have more than one group of actions and each group will run at the same time.
If you are now getting into this you might want to look at webCoRE.
You can define/edit pistons on your phone or your pc. You can also back them up or copy in/duplicate other peoples which also stops a lot of head sratching.
Makes life a lot easier.
Newbie question- just built my first Piston in the app on my phone. Is there a way to view/edit/create Pistons on the computer?
Only by using 'son of CoRE '.
webCoRE does the trick.
Iâve switched to webcore, but one of the pistons Iâd like to try to do does not seem to be supported yet, and I was hoping maybe someone had done that here.
I have three smart locks. I want to run a piston when the door is locked using the button on the outside.
it shows up in smartthings as door was locked with Code 0. It is different than someone manually locking the door from the inside. That just shows as door was manually locked.
Ultimately I can think of a few things I might do based on who unlocked the door, and this is the start. Any help is appreciated.
Because the âtime happensâ is a trigger and âtime isâ is a condition, and when you mix them, only the triggers cause things to happen. Replace the trigger with âtime is between sunset and midnightâ and use a simple piston instead, turn tge lights off on the else
Im having an issue with this goodnight piston. it triggers at 8:30pm, seems to work perfectly, but at 8:35pm the familyroom lights bump back up to 93%, after they faded to 35%. The piston isnt set up to do that and i cant find a good reason why its doing it⊠any ideas?
Are you sure there is nothing else fighting over the device with you? Like a CoRE piston?
Nothing i can see. I have CoRE still on my app list but no pistons named "Good Night"
In fact last night when it did this the Piston name was "Good Night."
So I ended up deleting it completely, rebuilding it and now its named "Good Night"
And last night looking at all those logs it reflected the Period, and now the period is gone. Making me think its coming from the same rebuilt Piston.
