where is that?
in the IDE > Live Logging > (select the name of the webCoRE parent app, when it shows up)
50a2ba25-0e42-4e95-b850-0bf86292dbd1 2:23:25 PM: debug Settings global vars to [@WakeUp:[v:1494083700000, t:time], @TimeOut:[v:40, t:integer], @WestLow:[v:0, t:integer], @TimeOut2:[v:72, t:integer], @WestHigh:[v:10, t:integer], @EastHigh:[v:10, t:integer], @EastLow:[v:0, t:integer]] (piston)
50a2ba25-0e42-4e95-b850-0bf86292dbd1 2:24:19 PM: debug Settings global vars to [@WakeUp:[v:1494083700000, t:time], @TimeOut:[v:40, t:integer], @WestLow:[v:0, t:integer], @TimeOut2:[v:72, t:integer], @WestHigh:[v:30, t:integer], @EastHigh:[v:0, t:integer], @EastLow:[v:0, t:integer]] (piston)
50a2ba25-0e42-4e95-b850-0bf86292dbd1 2:25:33 PM: debug Settings global vars to [@WakeUp:[v:1494083700000, t:time], @TimeOut:[v:480, t:integer], @WestLow:[v:0, t:integer], @TimeOut2:[v:97, t:integer], @WestHigh:[v:10, t:integer], @EastHigh:[v:0, t:integer], @EastLow:[v:0, t:integer]] (piston)
50a2ba25-0e42-4e95-b850-0bf86292dbd1 2:25:34 PM: debug Settings global vars to [@WakeUp:[v:1494083700000, t:time], @TimeOut:[v:480, t:integer], @WestLow:[v:0, t:integer], @TimeOut2:[v:97, t:integer], @WestHigh:[v:30, t:integer], @EastHigh:[v:0, t:integer], @EastLow:[v:0, t:integer]] (piston)
Dashboard is still showing:
Looks like two writes at the same time, fixed that, letās upgrade the child app now pleaseā¦ and run them again, there should only be ONE write for each run
Is the piston that sets @TimeOut2 running twice each time by any chance?
IIt looks like its just writing once now:
50a2ba25-0e42-4e95-b850-0bf86292dbd1 2:38:28 PM: debug Settings global vars to [@WakeUp:[v:1494083700000, t:time], @WestLow:[v:0, t:integer], @TimeOut:[v:480, t:integer], @WestHigh:[v:30, t:integer], @TimeOut2:[v:48, t:integer], @EastLow:[v:0, t:integer], @EastHigh:[v:0, t:integer]] (piston)
haha! Dashboard updated properly this time too!
So let me check one thing, am I finalizing the event twice, 'cause it makes no sense otherwiseā¦
this makes NO senseā¦ piston starts off with executeHandler (since youāre executing it by means of another piston) which executes handleEvents when then runs the whole logic and at the end runs finalizeEvent and then ā¦ well, ends. How does finalizeEvent run twice?! Are you sure your piston doesnāt run twice?
Ok, are you by any chance executing it in a loop? or twice? You can also check the location events in the IDE to find the events that cause the piston to execute - are they two?
Yeah sorry, I tried to rig up a virtual switch to test the piston more easily. Itās possible its also causing something else to trigger it again, but I thought I paused that.
It does look like its still being triggered twice.
Well, try and figure it out, felt like race conditionsā¦ thatās treacherous waters right thereā¦
yeah wow. Iāll look into it but I have no clue where its coming from.
welpā¦ Iām fried. 7 hours working on this is enough for me.
I still have old CoRE pistons. I still have routinesā¦ I canāt map the interaction between all of them. Live logging doesnāt seem to give enough info. Iām just going to scrap it all and start over someday. Until then Iāll just live with the brokeness, cuz, you know, smartthings.
Enable logs on all pistons, one by one. The logs are disabled by default
Wellā¦ ok solved I think.
seems the pistons with the switch statements needed to have automatic piston state on.
Also, I needed to turn my night mode piston back to āisā night not āchanges toā. Now everything is behaving properly.
Iād be happier about it if I didnāt just waste an entire sunny Saturday on it.
I really am grateful for all the help from @ady624. That was above and beyond.
Hey one more question guys. Iāve moved on to implementing the remaining pistons that I delete out of CoRE.
I have one using a 3d sensor for the garage door. Under CoRE there was an āorientationā value, but its not available under WebCoRE.
Yet to come?
Not available yet, will be
thank you!
