Well I guess I am SOL until someone else can figure out what is going wrong
So I am looking at the varibles that the weather sends and so far here is what is will provide with the setup for a variable
- Provides output for Temp, Humidity, Dew Point, Feels like, Pressure,
- No Output - UV, Wind, Wind Gust
I guess I could go through them all but not sure why this is. Maybe it is a string and not a numberâŠno tried that and does not work. Can someone else try this and see if you can get a variable for wind PLEASE. Here are the attributes that are found in this device handler. As you can see the ones missing are the ones that dont have output at all
lluminance: 10000
temperature: 66 F
humidity: 27 %
localSunrise: 6:45 AM
localSunset: 5:54 PM
city: Albuquerque, NM
timeZoneOffset: -0700
weather: Clear
water: false
weatherIcon: clear
forecastIcon: clear
feelsLike: 66 F
percentPrecip: 0 %
percentPrecipToday: 0.00 in.
percentPrecipLastHour: -999.00 in.
alert: Fire Weather Warning
alertKeys: [âFIR1487712120â]
dewpoint: 31 F
pressure: 30.10 inches (Falling)
solarradiation: â
visibility: 10.0 mi.
Iâll say that I just really noticed that when I set the timer to run the TTS I get an error in the app, it still continues, and then says automating, but of course never runs. Any way to find the error in the logs? Which area would I check?
Under the tasks you need to enable the task cancellation policy. Set it to cancel on piston or condition state change. That will cancel the task if the piston or condition changes. So when the door is closed that will cancel the task.
This means you are saying do the opposite of this. So if youâre condition is:
(Normal - this will turn the light on when the door is open)
If
front door is open
Then
Turn on light
(Negated - this will turn the light on when the door is not open)
If
!front door is open (notice the explanation point)
Then
Turn on light
same thing for Nest Weather, which uses WeatherUnderground station readings - uvindex, wind and windgusts are all 0, though they are declared as String attributes
eibyer has a fix somehow. He is able to see windspeed. I am going to get the handler and see what the difference is
Also how can the app have all the correct information but it just cant set the attribute to pass. Does not make any sense. I mean the weather app gives all the information that it can but 5 attributes canât be passedâŠ
I donât think any of those 3 are attributes though⊠They are prefixed with a âhouseâ (or whatever that icon means - are those actually functions/methods?) icon⊠The only âtrueâ attributes for Nest Weather are humidity, illuminance and temperature.
well I can pull all attributes but Wind, Windspeed, direction and UV. Everything else can be pulled and thrown int an attribute. If you look at the Smart weather tile device that show in there as attributes. The other once you mention, in the SW, are categories.
I am having a strange problem. Iâve been using CORE successfully for a while and have been very impressed with the flexibility and effectiveness.
Recently I seem to have lost the ability to creat. Ew pistons. When I try to do this, the UI pauses briefly and nothing happens.
Any advice welcome.
Simon
Check if youâre on the latest version.
def version() { return âv0.3.169.20170104â }
Added the following lines to the Smartweather app and now works like a champ thanks to eibyer
send(name: "wind", value: Math.round(obs.wind_mph) as String, unit: "MPH") // Added
send(name: "wind_gust_mph", value: Math.round(obs.wind_gust_mph) as String, unit: "MPH") // Added
send(name: "wind_degrees", value: Math.round(obs.wind_degrees) as String, unit: " Deg") // Added
send(name: âUVâ, value: Math.round(obs.UV) as String, unit: " ") // Added
Trying to create a piston in a certain way and canât quite figure out the settings.
What I want to do:
If A or if B then turn light ON
If C or if D then turn light OFF
I can do that with 2 pistons, but would think I could do it with just one.
The reason I am using CORE rather than Smart Lighting is I want to restrict
the piston based on another switch.
Any help would be appreciated.
How about a latching pistonâŠ
IF A or B Using light... > Turn On
BUT IF
C or D Using light... > Turn Off
Hello,
Would you be able to share the exact steps and selections (Capabilities, Conditions etc) you used to setup this Piston for Kodi?
Thanks in advance!
Hello I was wondering if somebody could explain the different commands pipes for actions within CoRE such as what âpollâ and ârefreshâ does?
Finally figured it out. I used an or-if with 2 conditions on each part.
Thanks for the suggestions.
I think the problem with or-if will be that C/D condition will never trigger if A/B is true.
XBOHDPuKC, That will never happen. A, B, C, D are all times. Unless I enter the wrong value then there should never be a conflict. But with my fat fingers I guess it could happen
Here is the piston that I have setup for dimming the lights (hue bulbs) when watching TV. Sorry, I tried to take a picture from the dashboard using my iphone but it just wouldnât copy to my pictures. So here is the copy paste:
Watch TV
Else-If v0.3.169.20170104 v0.2.14c.20160908 Wed, Sep 21 2016 @ 7:09 PM EDT Tue, Feb 14 2017 @ 9:14 PM EST
IF
⊠BasementXBMC status is playing
THENâŠ
Using Bottom of Stairs, Desk, Stairs, TV Room and Table LightâŠ
âș Set color to "Dark Blue"
âș Fade level from (not set)% to 5% in 6s
âș Set location mode to 'Movieâ
ELSE IF
⊠BasementXBMC status is paused
THENâŠ
âș Fade level from 5% to 70% in 8s
ELSE
THENâŠ
âș Set color to "White"
âș Fade level from (not set)% to 100% in 6s
Using locationâŠ
âș Set location mode to âHomeâ
If you need any help, let me know.
