I looked at the examples for setting the dim level of switches and created a piston that sets the level to 30 between 8:30 PM and Sunrise for the shower lights, which is what we use at night to avoid blinding ourselves. The problem, is that setting the level also turns on the lights. How would I set the level and leave the switch off? I tried adding turn off, but the simulate (changed to not in between to make the time check true) piston doesn’t work as the switch is in the same state.
My goal is to have it set to level 30 after 8:30 PM (kids bedtime) when the switch is off, but if the switch is on, it will wait for it to be turned off in that time frame and then set the level (so the next person isn’t rudely surprised).
I am trying to set a piston that when I arrive home it would change my mode based on executing a routine that sets the mode. Before I add the rest of my modes I want to ensure I am going down the right path.
In the THEN, I set restrictions for the days and time between but I am thinking there should be ORs between each item. So I would have the THEN and something OR something else OR something more.
Hi all, I’m trying to setup my first piston and am heaving a little trouble getting a particular piece done. I did some searching but didn’t find any similar questions (maybe my search skills suck). I’m trying to enable a scenario where my dimmer switch is on and I want to increase brightness to 100% if I tap “on” on the paddle again. Essentially:
Tap on -> dimmer turns on to previous value, e.g. 20%
Tap on any time later -> dimmer increases to 100%
I’m just don’t see a condition that listens for the “On” command when a switch is already on.
Hi everyone. I was just wondering if anyone has experience with recordClip(…). Is the record duration determined within my camera App (Arlo), or is it based on the parameter that can be set with that action? I wanted to record for a minute if motion is detected with in a certain time range, and I think I have the trigger and conditions set, but I was stumped by this portion.
I tried it without involving a variable and it immediately sets the level at 100.
My test piston was:
IF
Switch changes to on
AND
Switch is on
Using Switch
> Set level to 100
I’m thinking of doing this, completely untested
IF
AND
Variable switchedOn equals false
Using location...
> Set switchedOn to true
// Set the variable during initial tap
ELSEIF
AND
Variable switchedOn equals true
Using Switch...
> Set level 100
// Set level to 100 since the inital tap already registered
ELSEIF
Switch changes to off
AND
Using location
> Set switchedOn to false
// Set the variable back to false for the next tap
I checked the live logging briefly when I tried the first piston. The second tap was registering as another on (for that device I have). I did not have time to give the second version a try though.
I’m trying to set up a piston where my schlage lock will change alarm mode based on the hub mode. When I go into the lock event history, it is setting the value as “setAlarmMode” but the mode isn’t actually changing
Thanks @eibyer, I think the problem is that the dimmer doesn’t send another “on” command of is already on. At least the Recent Activity view doesn’t show it.
Any idea if this is the case? Any way around this? There is a double tap smart app, this makes me think a solution is possible.
Hey all I’ve been trying to figure out this simple piston and for the life of me cannot get it working. I’m sure it’s something easy.
What I want it to do is text me when one of my temperature sensors is above or below a set number, but only once every couple hours so I’m not getting a bunch of messages.
Everything works except it will not wait 120 minutes until it fired again. It will continue to send SMS messages as the temperature changes every time.
I know the issue is the wait command at the end, I just don’t know what to put in its place
Here’s what I have so far:
I didn’t check the recent view on the st app but I did look the web IDE live logging. I will give that second piston a try when I get home (if I don’t sidetracked).
There’s an option “piston or state change only” that you can try enabling but it will still ignore the 120 minute wait you have. If you need that 120 minute wait, you will have probably have to involve a variable that can be checked if the notification has been triggered already and then you’ll have a timer in that piston that will reset that variable back to false after 120 minutes waiting for another event.
I’m with you. I think it is going to depend on what type of switch / dimmer you use. I have the GE dimmer installed. I can not see any events in live logging or Event list for that switch on the IDE if the switch is already in the state your trying to switch to.
I turned it on and pressed the on button again. The original on is in the IDE event list but not any of the latter. I do see my CoRe piston sending the level commands from my auto control. Which is interesting but really does you no good. If you can’t see the switched pressed again then you can’t trigger your CoRE piston on that event.
Works - but the sim switch I’m using stays on ,negating running again.
Tried a button but Alexa does not seem to work. Need a way to reset the sim back to Off.
Also is the only turn off a delayed off? It works.but need to set a time.
interval timer is for a planned hydroponics setup net Summer, on 10-20 seconds and then off for 15 minutes repeat. Last time I did this I was using industrial timers but want to be able to track power usage. I could always buy a timer and use a ST device to track power - but seems excessive.
