Trying to build in a debounce on a switch. I am trying to improve on the Mood Cube interface by building in a delay from start of motion until the start of an action. (The not moving is a 12 second delay, a little long for the application.)
I want to do:
If (motion) {
wait 3 seconds
If Position == “Up” {thing one}
else if Position == “Down” {thing two}
else if Position == "Right {thing3}
Yep. Enable expert mode and use individual actions in a basic piston. Add the stay trigger, then add a group. Change the AND between the stay trigger and the group by tapping on it. Select THEN IF.
IF
Motion stays active for 3 seconds
THEN IF
Orientation is up >>> when true > do something
ELSE IF
Orientation is down >>> when true > do something else
ELSE IF
etc.
I’m having a problem understanding the groups and how to set them up properly. I end up getting lost when I get a couple groups deep.
Here is what I want to accomplish:
If Garage Door is open
Then
Fan Off
Wait 3 Min
Garage Thermostat Off
Else IF
If Garage Door is closed
AND
(Garage Temp is less than 35F
Then
Set Garage Thermostat to Heat
Wait 10 Seconds
Set Garage Thermostat setpoint to 40F
Fan On)
OR
(Garage Temp is greater than or equal to 40F
Then
Wait 10 Seconds
Set Garage Thermostat setpoint to 35F
Fan Off)
Here is what I have so far.
Can anyone help me fix this to accomplish the above?
I have this piston written which is designed to activate by 2 methods, one is a virtual switch, one is a physical switch… and the piston keeps them tied together. I put a notification in the piston and it sends it twice. I imagine thats because its activating the piston for the one switch first, then as it flips the other, reactivates itself again.
I also have a need for a condition I want to be true only when at least 3 windows are open. Is that going to require introducing special variables?
bamarayne
2313
Well, first thing you have to do is upload a picture of the piston you already have.
So its a whole house fan I’ve automated, but, I want to be sure that there is sufficient ventillation so the fan doesnt kick in when its not wise, for example, if one sensor is stuck and not actually closed, or one bedroom window is open but the door is closed. I feel as though “at least x” and in my case x would be 3, should be a simpler thing for me to do. Alas. If you have any ideas!
Need some help on a basic piston turning of a light when no changes in a motion sensor is seen in 5 minutes. Do I get the logic wrong? In dashboard it evaluates to FALSE forever, but if i simulate it does what it is supposed to do.
bamarayne
2318
In the first IF create a Boolean variable (fan timer) and have that as a condition. The condition will be true.
IF
Any switch changes to on
And
{Fan timer} is false
THEN
Do stuff and
Set {fan timer} to true
BUT IF
Any switch changes to off
THEN
Do stuff and
WAIT x minutes
Set {fan timer} to false
Did you see any logic faults in the piston i posted? @bamarayne
bamarayne
2322
No, I didn’t, but until @ady624 can look into this and see if there is a bug, try this.
Using a latching piston.
IF
Motion is active
And
Kitchen light is on
THEN
Leave this blank
BUT IF
Motion is inactive
THEN
Wait 5 minutes
Turn off light (cancel on piston state change)
I’m struggling with my setup. I’m using a simple basic piston defined as follows -
If motion sensor 1 or motion sensor 2 is active, then
turn lights on
wait for piston state change (i.e. no motion)
Dim lights to 10%
wait 1 minute
turn off lights
It kind of works as expected (i.e. lights turn on / dim / new motion, turn on again)
But sometimes the lights stay on:( and you can see in dashboard that the set level 10% and the turn off are xxxxSeconds past due…
Any tips? Is there a better way to be doing this? I think maybe the system is being overwhlemed w/ schedules over schedules over schedules when the task re-triggers?
