Past 1259PM?
The above all makes sense, but if I am setting a variable on a condition, and I do not use that variable in any other condition within the current Piston again (it will only be used to restrict an action), shouldnât that work?
Is the restrict of an action in the same piston?
Yes, I am trying to use the variable I set in the condition to restrict an action in the same piston.
OK, let me try and explain thisâŠ
If Condition #1
Individual Action #1 (Set Variable)
Then
Action #2 (restricted by variable set in Individual Action #1)
I think this is your scenario.
So your piston fires and it evaluates Condition #1 which is true, so it schedules the Individual Action #1 to occur (doesnât actually perform this action, just schedules it)
And because Condition #1 is true it schedules Action #2 (Since the Individual Action #1 has been schedule but not run the restriction doesnât work).
And finally the scheduled actions (Individual Action #1 & Action #2) run. Does this help to clarify it?
You are very right Sir, if you would excuse my âveryâ
That is exactly my use case, and Iâm so over this.
Thank you both @ady624 and @ryan.ray for clarifying that for me.
Do you see any way around this, another possible way I can achieve this case successfully?
What timezone are you in? Looks like a time zone issue or something weird. Some 3 minutes off⊠1:15pm is 13:15, plus 10:42 means 23:57, which is 3 minutes off from midnight. Is you phoneâs time set to automatic? Is your phoneâs date and time off by 3 minutes?
Yes. Me allowing Set Variable to run immediately (during the condition evaluation). Iâll think about that, youâre not the first who expects that to happen⊠The main beef is with Waits, but I can sort that out, so that if you use setVariable without a wait, then you get that set immediately, so you can use it in subsequent condition evaluations.
EST. 1:58pm locally here. Phone is displaying the time fine, and the time IDE is reporting in the logs match. But nothing ever comes up in logs under CoRE.
Well, itâs almost 2:01 here⊠Check the time online, see if matches your phone
Would love that!
This Rule Engine is my life right now. Mmmm, Iâm lovinâ it more than McDonaldâs
Yeah my time is fine. Updated automatically by my carrier AT&T. Matches the time on my hub and time.gov.
Xobniu, this piston setup works for me just fine. If you click on the CoRE Dashboard, do you see the piston go from False to True at the time set? Also, try a different outlet.
Iâve set up above piston which simulates lights when weâre not home. Itâs fit for purpose now but as sunset gets earlier from 21st June need a way of calculating length of time between custom times in condition. Then somehow using this to determine how long a loop for the lights going on and off lasts for. Can this be done in CoRE. Is there a system variable for sunset time?
I know there is the Vacation Lighting Director App that does this, but wanted to try with CoRE as I like all my automation in one place so to speak
just a quick question - im really loving CoRE, but one thing i cant get working - execute routine ( example of use i want : IF no motion bedroom sensor, THEN execute routine away) doesnât let me select this option. I get âerror refreshing pageâ. is this aspect not working yetâŠif so i can wait. i dont need to use routines in my pistons, but just makes life easier and also id like to so the widget info in android updates correctly. im using the V0.1.09e.20160617
Thank you in advance
Is there any way to get above 2 pistons into 1? Because the top piston has a trigger I cant put another OR statement in the bottom piston as the trigger prevents all the other conditions from evaluating.
Another question related to TOS and TCP.
If the Hall light is on because of motion in the bottom piston. If someone arrives home will the hall light turn off after 10 minutes or will it still turn off after the 3 minutes/fade section. Still havenât got my head round TCP/TOS
Logs please? Enable debugging in the piston, save, then try to modify it and see if you get an error in the logs. Thank you
