Could it be that the first time around both the time and the switch triggered events at roughly the same time? Or did you use Simulate?
Feature request: Would it be possible to have
(1) the ability to turn on/off for each created piston on the piston list screen, and
(2) ability to have a switch disable the piston (you may already be working on this or someone else suggested)
thanks. did not think it would be under that.
I did not use simulate, but I did test it before because I had a time condition with the trigger, so I tried it while the condition was false, and then I tried it after the condition was true. The screens I sent are of the condition being true. Like you said, I also think it’s a timing thing and not a bug.
v0.0.04c.20160526 - Alpha test version - Fixed a bug with item in list for is_one_of.
- when I get to revamp the CoRE, at beta stage
- sure thing
Thanks! I am absolutely loving this App thus far !!!
Any suggestions on how to implement the logic below or if it’s even possible at this point?
IF Contact changes to closed
set x = 0
while contact is closed and x < 5
wait 4 minutes
for 0 to x
using siren
speakText("beep ${x * 50}")
wait 1 second
x++
I’m trying to avoid having to do something like:
If Contact is closed
Using Siren
wait 4 minutes
beep 0
wait 4 minutes
beep 50
wait 1 second
beep 50
wait 4 minutes
beep 100
wait 1 second
beep 100
wait 1 second
beep 100
wait 4 minutes
beep 150
wait 1 second
beep 150
wait 1 second
beep 150
wait 1 second
beep 150
etc...
else
using siren
cancel pending actions
I’m playing around with the “save attribute to variable” option. What is the aggregation parameter supposed to be?
Save is not ready. If you select multiple devices, you only save one value, hence the need for aggregation fumctions: min, avg, max, sum, count, etc
Hmm… Challenge. Accepted.
Got it, thanks!
I think someone will have to create a similar image because the one that was posted is watermarked and has usage restrictions.
Hey, what’s that Home Cloud Hub about?
Yep, license issues. Any designer around? How much does that pic cost?
…nothing… I think…
(integrates AT&T Digital Life and MyQ)
Oh cool. Thanks for looking into that for me. Saved me a search
