so why is my rule constantly re-evaluating as well as rescheduling the timer then?
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:20 PM: trace ╔═══ Event processing took 117ms
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:20 PM: trace ╚═══ Processing event power for device Livingroom - TV Outlet with id 769ce4ca-c15d-4022-a482-0f2d17c5507b, value 117.4, generated on Fri May 20 20:49:20 UTC 2016, about 494ms ago
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:20 PM: trace ╔═══ Task processing took 146ms
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:20 PM: trace ║░░░ Removing any existing ST safety nets
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:20 PM: trace ║░░░ Installing ST safety net
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:20 PM: trace ║░░░ Rescheduling time triggers
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:20 PM: trace ╚═══ Processing tasks
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:20 PM: trace ╔═══ Event processing took 114ms
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:20 PM: trace ╚═══ Processing event power for device Livingroom - TV Outlet with id 769ce4ca-c15d-4022-a482-0f2d17c5507b, value 117.4, generated on Fri May 20 20:49:20 UTC 2016, about 495ms ago
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:18 PM: trace ╔═══ Task processing took 147ms
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:18 PM: trace ║░░░ Removing any existing ST safety nets
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:18 PM: trace ║░░░ Installing ST safety net
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:18 PM: trace ║░░░ Rescheduling time triggers
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:18 PM: trace ╚═══ Processing tasks
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:18 PM: trace ╔═══ Event processing took 105ms
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:18 PM: trace ╚═══ Processing event power for device Livingroom - TV Outlet with id 769ce4ca-c15d-4022-a482-0f2d17c5507b, value 115.2, generated on Fri May 20 20:49:17 UTC 2016, about 1024ms ago
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:18 PM: trace ╔═══ Task processing took 148ms
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:18 PM: trace ║░░░ Removing any existing ST safety nets
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:18 PM: trace ║░░░ Installing ST safety net
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:18 PM: trace ║░░░ Rescheduling time triggers
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:18 PM: trace ╚═══ Processing tasks
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:18 PM: trace ╔═══ Event processing took 126ms
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:18 PM: trace ╚═══ Processing event power for device Livingroom - TV Outlet with id 769ce4ca-c15d-4022-a482-0f2d17c5507b, value 115.2, generated on Fri May 20 20:49:17 UTC 2016, about 501ms ago
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:17 PM: trace ╔═══ Task processing took 171ms
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:17 PM: trace ║░░░ Removing any existing ST safety nets
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:17 PM: trace ║░░░ Installing ST safety net
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:17 PM: trace ║░░░ Rescheduling time triggers
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:17 PM: trace ╚═══ Processing tasks
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:17 PM: trace ╔═══ Event processing took 110ms
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:16 PM: trace ╚═══ Processing event power for device Livingroom - TV Outlet with id 769ce4ca-c15d-4022-a482-0f2d17c5507b, value 116, generated on Fri May 20 20:49:16 UTC 2016, about 503ms ago
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:17 PM: trace ╔═══ Task processing took 144ms
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:17 PM: trace ║░░░ Removing any existing ST safety nets
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:17 PM: trace ║░░░ Installing ST safety net
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:16 PM: trace ║░░░ Rescheduling time triggers
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:16 PM: trace ╚═══ Processing tasks
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:16 PM: trace ╔═══ Event processing took 100ms
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:16 PM: trace ╚═══ Processing event power for device Livingroom - TV Outlet with id 769ce4ca-c15d-4022-a482-0f2d17c5507b, value 116, generated on Fri May 20 20:49:16 UTC 2016, about 493ms ago
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:16 PM: trace ╔═══ Task processing took 151ms
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:16 PM: trace ║░░░ Removing any existing ST safety nets
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:16 PM: trace ║░░░ Installing ST safety net
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:16 PM: trace ╔═══ Event processing took 106ms
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:15 PM: trace ╚═══ Processing event power for device Livingroom - TV Outlet with id 769ce4ca-c15d-4022-a482-0f2d17c5507b, value 114.1, generated on Fri May 20 20:49:15 UTC 2016, about 732ms ago
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:16 PM: trace ╔═══ Task processing took 131ms
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:16 PM: trace ║░░░ Removing any existing ST safety nets
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:16 PM: trace ║░░░ Installing ST safety net
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:16 PM: trace ║░░░ Rescheduling time triggers
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:16 PM: trace ╚═══ Processing tasks
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:16 PM: trace ╔═══ Event processing took 110ms
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:15 PM: trace ╚═══ Processing event power for device Livingroom - TV Outlet with id 769ce4ca-c15d-4022-a482-0f2d17c5507b, value 114.1, generated on Fri May 20 20:49:15 UTC 2016, about 732ms ago
61f78345-2058-49b0-b63d-f7c850f576f9 9:49:15 PM: debug Poll is calling refresh
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:15 PM: trace ╔═══ Task processing took 509ms
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:15 PM: trace ║░░░ Removing any existing ST safety nets
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:14 PM: info ║░░░ Executing: [Livingroom - vSwitch].on()
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:14 PM: info ║░░░ Executing: [Livingroom - Floor Lamp Bulb].on()
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:14 PM: info ║░░░ Executing with parameters: [Livingroom - Floor Lamp Bulb].setLevel([25])
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:14 PM: info ║░░░ Executing with parameters: [Livingroom - Floor Lamp Bulb].setSaturation([80])
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:14 PM: info ║░░░ Executing with parameters: [Livingroom - Floor Lamp Bulb].setHue([20])
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:14 PM: trace ║░░░ Installing ST safety net
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:14 PM: trace ║░░░ Rescheduling time triggers
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:14 PM: trace ╚═══ Processing tasks
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:14 PM: trace ╔═══ Event processing took 116ms
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:14 PM: trace ╚═══ Processing event power for device Livingroom - TV Outlet with id 769ce4ca-c15d-4022-a482-0f2d17c5507b, value 114.8, generated on Fri May 20 20:49:13 UTC 2016, about 487ms ago
9c41aad9-2aa4-45cc-8c2e-15a19ce2c5ae 9:49:14 PM: trace setHue(20)
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:13 PM: trace ╔═══ Task processing took 503ms
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:13 PM: trace ║░░░ Removing any existing ST safety nets
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:13 PM: info ║░░░ Executing: [Livingroom - vSwitch].on()
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:13 PM: info ║░░░ Executing: [Livingroom - Floor Lamp Bulb].on()
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:13 PM: info ║░░░ Executing with parameters: [Livingroom - Floor Lamp Bulb].setLevel([25])
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:13 PM: info ║░░░ Executing with parameters: [Livingroom - Floor Lamp Bulb].setSaturation([80])
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:13 PM: info ║░░░ Executing with parameters: [Livingroom - Floor Lamp Bulb].setHue([20])
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:13 PM: trace ║░░░ Installing ST safety net
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:13 PM: trace ║░░░ Rescheduling time triggers
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:13 PM: trace ╚═══ Processing tasks
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:13 PM: trace ╔═══ Event processing took 134ms
312e63ba-bf10-4dd6-907c-d403c3617a6b 9:49:13 PM: trace ╚═══ Processing event power for device Livingroom - TV Outlet with id 769ce4ca-c15d-4022-a482-0f2d17c5507b, value 115.5, generated on Fri May 20 20:49:12 UTC 2016, about 488ms ago
9c41aad9-2aa4-45cc-8c2e-15a19ce2c5ae 9:49:13 PM: trace setSaturation(80)
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:13 PM: trace ╔═══ Task processing took 158ms
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:13 PM: trace ║░░░ Removing any existing ST safety nets
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:13 PM: trace ║░░░ Installing ST safety net
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:13 PM: trace ║░░░ Rescheduling time triggers
5adc2549-f02a-4157-80c0-5244c02a12fc 9:49:13 PM: trace ╚═══ Processing tasks
this would be the same for LUX as it changes I would think
