So C++?
Setting modes can be done directly from SmartTiles, if youāre using it.
I donāt know if Iām just being slow but Iām trying to create a piston which will notify me if my garage door has been open for 15, 30 and 60 minutes. Currently it will just start the countdown when the garage door is opened but doesnāt stop/reset it once itās closed. What am I doing wrong?!
enable Cancel on piston state change for the action, see Task Cancellation Policy
Well, that just makes you the Nth+1 member of the club, then!
Classy! The futureās so bright, I gotta wearā¦ Write once, debug everywhere!
For those adventurous enough, try the workflow blocks in Actionsā¦
v0.0.080.20160610 - Alpha test version - Welcome to CoRE++ - actions are now much smarter, with for, while (not enabled yet), switch and if-else-if blocks
I havenāt finished while yet. This may break things. No validation of structure sanity yet, so make sure you write code responsibly. Feedback please.
Variable issues again, not sure if its meā¦from past experience probably is!
The above piston normally has just Jon & Denise presence sensors. Iāve added test presence sensor for testing.
This morning I left and variable @notHome did not populate with Jon. I added test sensor and then set it to āawayā then variable populated with both Jon and Test Presence sensor.
Denise then left and same thing happened, nothing changed until i altered the test presence sensors presence
Denise arrived home and again variable @home didnāt populate and @notHome didnāt update and remove Denise until, again test sensor was changed manually.
The Jon & Denise sensors were definitely logged as away/home correctly as i have another piston which sends SMS when sensors arrive and leave
I am on version 080 now, but was on previous version when issues were seen
So if the things I need are in the restrictions then Iāll have to use 2 pistons to have a different weekday and weekend schedule? Canāt be done in one piston, can it?
Time trigger
OR
Time trigger
OR
Time trigger
Etc.
Each time trigger has its own restrictions.
So I would create a group in which I would put two time triggers with OR between them, then you can add additional conditions outside the group, if tou have any.
I will check that.
Yep, if you can write it, it should work. Modular structureā¦
UPDATE: Except maybe for having triggers with AND between them. When using triggers, only ONE trigger is true during any evaluationā¦ So having several triggers with AND between them wonāt yield the expected resultsā¦
Awesomeā¦ thanks a milā¦
How do you enable this? Iām on the latest version, but Iām not seeing the āFORā option?
Itās a ātaskāā¦
Thanks, I canāt believe I didnāt see it before.
Hi all,
I need a little help configure a simple loop pistonā¦
I canāt seem to be able to get it to work,
Here is my configuration:
Any help will be greatā¦
Gil
Let me test that. Pretty new stuff, those loops
First off, Iād use
IF switch is on
THEN {loop stuff}
ELSE {temp and saturation stuff}
@gilh, you need to be on latest version, v0.0.080 for those to work. I just implemented them last nightā¦ Theyād look slightly different (FOR 5 CYCLES DOā¦ LOOP AFTER 30s)
