Hi, what would be the procedure If I join a node through a zigbee router and while it was commissioned, the coordinator missed the signal, so no device shows up on the app but the node is effectively part of the network, is there a way to refresh the network?
In my case 9 out of 10 smartthings hub misses the signal so no device is added but the node successfully commissions.
@BroderickCarlin @JDRoberts
Are you using a custom device handler for the device?
Yes, if I add the node directly from the cooordinator it always works.
By any chance are you just not hitting the bug where the device is included, but not added immediately, but if you start the pairing again in the app it shows up as added?
Try re-publishing your custom DTH, resetting the device and adding again.
