Convert volume/dimmer from 100% to 1-10 scale
Anyone has an idea what the easiest way is to convert a media device that sets the volume from 1 to 100, into a 1 to 10 scale to use with Alexa? I want to tell Alexa set TV to 4 (that would correspond to 40% in the media handler). It could be at handler level or virtual device.
Alexa “natively” supports percent as a part of the Smart / Connected Home features. I highly recommend that approach.
If you write or modify a custom Skill, then you can parse out any value you want.
Meanwhile, you could create 10 virtual switches or phrases named 1 to 10, but Alexa doesn’t even like Devices with numeric names.
Well, I don’t want a custom skill, or have ten virtual devices. I think I can modify a virtual dimmer and scale up the command that comes from Alexa. So I tell Alexa set TV volume to 5, then multiply that by ten to adjust the dimmer. With Ask Alexa or Echosistant is easier, because like you said I can customize the skill, but I’d like to say Alexa set TV to 5 or just Alexa TV 5. Just tested with a regular dimmer and the command worked, just need to find the best way to convert it…
Thanks for making me think! The easiest way is to do it in my AVR handler. Use Alexa to set level 1 to 10 and I multiply that by 10 and send it to my TV. If command comes > 10, then I max out at 100%.
