Controlling DALI systems via SmartThings app
Hi there
My company has recently received several requests to enable controlling of existing DALI lighting systems via SmartThings app. Our current solution would be to install a ST compatible gateway to Z-wave such as Aeotec Smart Home Hub together with a Z-wave DALI controller such as Fibaro SR-2411. I have no experience with pairing Z-wave devices from different vendors, so the question is: is this a solution that should work in practice i.e. should we expect any problems having in mind that Fibaro’s DALI controller is not registered into SmartThings ecosystem?
Should we prefer direct solutions such as using e.g. Shelly DALI Dimmer Gen3, which is registered in SmartThings ecosystem?
Many thanks in advance!
