I am trying to create API endpoints using the groovy like so:
* App Endpoint API Access Example
* Author: SmartThings
* Changes
* Change 1: 2014-02-25
* Initial version
* Change 2: 2014-03-02
* Added Capabilities
// Automatically generated. Make future change here.
definition(
namespace: "HueMadness",
author: "STI Lab",
description: "Philips Hue Control App that appears in SmartThings Labs on the mobile app",
category: "SmartThings Labs",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
oauth: true)
preferences {
section("Allow Endpoint to Control These Things...") {
input "switches", "capability.switch", title: "Which Switches?", multiple: true
input "color", "capability.colorControl", title: "Color Control", required: false, multiple: true
input "level", "capability.switchLevel", title: "Level Control", required: false, multiple: true
section("Control Smart Locks") {
//input "locks", "capability.lock", title: "Which Locks?", multiple: true
mappings {
path("/switches") {
action: [
GET: "listSwitches"
path("/switches/:id") {
action: [
GET: "showSwitch"
path("/switches/:id/:command") {
action: [
PUT: "updateSwitch"
//all capabilities
path("/capabilities") {
action:
GET: "capabilitiesList"
path("/level/:id/:command") {
action: [
PUT: "updateLevel"
def installed() {}
def updated() {}
//switches
def listSwitches() {
switches.collect{device(it,"switch")}
def showSwitch() {
show(switches, "switch")
void updateSwitch() {
update(switches)
void updateLevel() {
updateLvl(level)
def deviceHandler(evt) {}
private void update(devices) {
log.debug "update, request: params: ${params}, devices: $devices.id"
//def command = request.JSON?.command
def command = params.command
//let's create a toggle option here
if (command)
def device = devices.find { it.id == params.id }
if (!device) {
httpError(404, "Device not found")
} else {
if(command == "toggle")
if(device.currentValue('switch') == "on")
device.off();
else
device.on();
else
device."$command"()
private show(devices, type) {
if (!device) {
else {
def attributeName = type == "motionSensor" ? "motion" : type
def s = device.currentState(attributeName)
[id: device.id, label: device.displayName, value: s?.value, unitTime: s?.date?.time, type: type]
def capabilitiesList() {
def cap = []
allDevices().each {
it.capabilities.each { cap.add(it.toString().toLowerCase()) }
[capabilities : cap.unique { a, b -> a <=> b }]
// create an unique array of all devices the user has given us access to
def allDevices() {
def valuesMap = switches + color + level
valuesMap.unique { a, b -> a.id <=> b.id };
private device(it, type) {
it ? [id: it.id, label: it.label, type: type] : null
private void updateLvl(devices) {
// log.debug "update, request: params: ${params}, level: $level.id"
log.debug "update, request: params: ${params}, devices: $devices.id, levl: ${params.param4}"
def lvel = params.lvl
log.debug "level: ${params.lvl}"
if (command)
def device = level.find { it.id == params.id }
if (!device) {
} else {
if(device.currentValue('switch') == "on"){
device.setLevel(50)
device.off()
else{
device.setLevel(100)
device.off()
device.on();
else
device.setLevel(35)
device.off()
device."$command"()
private levelUp() {
def level = Math.min(currentSwitchLevel + 10, 100)
log.debug "level = $level"
level?.setLevel(level)
private levelDown() {
def level = Math.max(currentSwitchLevel - 10, 10)
private getCurrentSwitchLevel() {
def level = 0
level.each {
level = Math.max(it.currentValue("level")?.toInteger() ?: 0, level)
level.toInteger()
So, when I try to run a cURL like so:
“curl --header “Authorization: Bearer XXX-XXX-XXX-XXX-XXX” -X PUT https://graph.api.smartthings.com/api/smartapps/installations/XXX-XXX-XXX-XXX-XXX/level/myDeviceID/up”
returns either a SmartAppException or Access Denied. I am not sure the exact process for adjusting brightness and color for a Philips Hue and I need to ensure that I can create an API endpoint to integrate in an Android app.
Any pointers would be greatly helpful. Thank you.
