bridaus
(Brian)
September 2, 2015, 1:11am
1
I have the sinking feeling this is a dumb question.
Is there an already existing virtual device that is a switch that will turn off after a configurable amount of time (config can be in the code).
I think the search terms are too generic to find me the specific thing I’m looking for…
If not off the top of someone’s head, I know I can code this when I have some time. But it has to already exist…
bridaus
(Brian)
September 2, 2015, 1:33am
2
And related to this question: What is the most reliable physical contact switch (or method to implement a virtual one), that will turn on for a period of time, and then turn off (approx 1-2 minutes). I can do this virtually (in fact I made an app that scheduled an off and a safety off for a power plug, but that still makes me nervous (this is a backwash for a water filter). I’m turning on and off a 24volt transformer running on 120.
I am using the on/off button tile virtual switch and have configured it in the app to turn it off after 5 minutes. It works well for me.
It’s in short cut groups: “turn off after a period of time.”
SHORTCUT GROUPS WERE REPLACED IN THE SEPTEMBER 2015 VERSION OF THE MOBILE APP BY “SMART LIGHTS,” AN EVEN MORE POWERFUL AND MUCH MORE INTUITIVE WAY OF SETTING UP LIGHTING RULES.
I will leave this post up for a few more weeks to give everyone time to transition over to the new mobile app. But pretty much everything below this line will no longer apply once you do you have the new mobile app version.
Instead, see the “How to Group Lights” article in the community-created wiki.
http://thingsthataresmart.wiki/index.php?title=How_to_Group_Lights_Together
One of the most powerful features in the SmartThings mobile app is the use of Shortcut Groups. There are literally dozens of built in features for scheduling groups, from “turn off after X minutes” to “turn on when someo…
I think any switch will work for this, virtual or physical.
johnathan398
(Johnathan Fullman)
September 2, 2015, 4:43am
5
I wrote my own custom app for this.
Turns off after a configurable period of time
If it turns off on you, turn it back on within x seconds and it will disable auto-shutoff.
Double-tap the switch’s on setting and it will prevent auto-shutoff.
I use it for rooms I’m usually in for only minutes at a time. Closets, garage, etc.
My source is available on git hub .
this app works like a bomb… only question is there any way of doing less than a minute… i am using a port to turn on and off a relay for my garage door… it only needs to be on for a few seconds… didn’t know if you had that answer??
I added support for a seconds component in my program . Enjoy!
you are awesome… I am impressed that even after writing this so long ago you still keep it updated… thanx man
