Current Version: 0x1F015310
Target Version: 0x1F075310
Last Updated: 2017-02-22 12:06 AM CET
Last Checked: 2017-08-03 10:34 AM CEST
Is this normal? Current Version and Target Version don’t match. Please advice.
Retrieve Current Setting
Zigbee OTA is enabled for all devices
Try this.
Disconnect the Network cable, power and batteries from hub for 30 min. Reconnect and power it on. Hopefully that should do it. This is how I got the update.
@Ghosted, or you can rejoin the sensor by following the factory reset process for the device, and the firmware should update in a day or 2. I’ve had to do that a few times already.
If it’s an Iris sensor, here’s how:
https://support.smartthings.com/hc/en-us/articles/217199866-Iris-Contact-Sensor
