Connection to Domoticz defined devices like Blinds and On/Off switches
somfy
x10
rgbw
project_shades
(Martin Verbeek) #766
looks good. I took a look at device logic, when you hit the Preset tile it will issue the Stop command to domoticz…could you check if you do a Stop in domoticz that all is working as expected? And check the log in both ST and Domoticz to see if any error is occuring…
(Arnoud) #767
Yes, a stop in Domoticz works as expected.
When I trigger Up & Down from the ST app I see this in the log:
2019-03-14 18:43:33.124 Status: User: Admin initiated a switch command (128/Rolluik Werkkamer/On)
2019-03-14 18:43:33.127 Status: Notification: IDX 128 on
2019-03-14 18:43:41.806 Status: User: Admin initiated a switch command (128/Rolluik Werkkamer/Off)
2019-03-14 18:43:41.810 Status: Notification: IDX 128 off
pressing the Preset button does not generate any response in the Domoticz log or from the blinds.
This is what it looks like from within Domoticz:
Slides00047
If I hit the red STOP button the blind will move to the preset position, and I see this in the logs:
2019-03-14 18:47:58.437 Status: User: Admin initiated a switch command (128/Rolluik Werkkamer/Stop)
2019-03-14 18:47:58.441 Status: Notification: IDX 128 off
Hitting the Preset button from within the app gets no action in the ST IDE logs. The up/down button generate the traces that you would expect.
No errors anywhere…
(Martin Verbeek) #768
This was weird, normally the Windows Shade capability has the presetPosition command defined automatically, this is somehow gone away now (maybe named otherwise now) Anyhow, i have name the command explicit now, which makes it work. So refresh the domoticzBlind device handler, should work now. Also a small change to domotics server.
(Arnoud) #769
Yep, that has fixed it.
Is there a way to figure out the capabilities of a blind and only show the options relevant to it? I mean, I can comment the windspeed, wind direction etc out from the groovy source, but it would be much easier (for the end user, not for you) to have this only appear if this is relevant for this blind?
(Martin Verbeek) #770
If you delete the device in st, it will be readded without the weather
met vriendelijke groeten,
Martin
(Arnoud) #771
Ok, now that was working as expected I turned to the power meter.
Looking at the source I was expecting to be able to generate a graphical report similar to what I see in Domoticz, but that is not working, right?
I did make a change to the sourcecode to make the low-counter also work.
I noticed that in the “Recently’” information the “consumptionlow” was one lowercase word, while in the source it was written with a capital L. I changed it to:
valueTile("consumptionLow", "device.consumptionlow", width: 2, height: 2) {
	state "consumptionlow", label:'Low ${currentValue} W', defaultState: true
And now it shows up correctly.
“consumption high” in the log is spelled with all lowercase, but a space in between.
Is there a way to get rid of the “.0” at the end of every reading?
Oh, and I deleted the space before the “W” to prevent the ‘W’’ from being on a different line. The text is slightly smaller now, but I think it looks better:
(Martin Verbeek) #772
Thx Arnoud, will reflect those on git as well.
Graph does not work very well in St. Lot of issues.
Martin
