Connecting ST HUB to the internet with proxy
Hi,
I’m trying to connect the HUB with a cable that needs a proxy to be configured.
When I plug the cable the light becomes steady blue.
I’ve tried in another place and got everything right.
Is there any way to configure the proxy in the ST HUB?
steady blue means it has an IP address but its not getting a connection to the server. It connects via port 443 (HTTPS) so make sure thats open to it.
Hi I meet the same problem. Have you solved it?
Not really, I found out that there’s no way to configure the proxy on the HUB.
I had to get another cable with direct internet connection without proxy.
