I can’t remember if I changed anything, but here is the code that I am currently using:
* Fortrezz MIMOlite
* Author: Based on SmartThings code
* Date: 2014-03-6
// for the UI
metadata {
// Automatically generated. Make future change here.
definition (name: "Mimo lite", author: "carlos@carlossaldarriaga.com") {
capability "Polling"
capability "Refresh"
capability "Switch"
capability "Contact Sensor"
// simulator metadata
simulator {
status "on": "command: 2003, payload: FF"
status "off": "command: 2003, payload: 00"
// reply messages
reply "2001FF,delay 100,2502": "command: 2503, payload: FF"
reply "200100,delay 100,2502": "command: 2503, payload: 00"
// status messages
status "open": "command: 2001, payload: FF"
status "closed": "command: 2001, payload: 00"
// UI tile definitions
tiles {
standardTile("switch", "device.switch", width: 2, height: 2, canChangeIcon: true) {
state "on", label: '${name}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#79b821"
state "off", label: '${name}', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
standardTile("contact", "device.contact", inactiveLabel: false) {
state "open", label: '${name}', icon: "st.contact.contact.open", backgroundColor: "#ffa81e"
state "closed", label: '${name}', icon: "st.contact.contact.closed", backgroundColor: "#79b821"
standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat") {
state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
valueTile("alarm", "device.alarm", inactiveLabel: false) {
state "alarm", label:'${currentValue}'
main (["switch", "contact"])
details(["switch", "contact", "refresh", "alarm"])
def result = null
def cmd = zwave.parse(description, [0x20: 1, 0x84: 1, 0x30: 1, 0x70: 1])
if (cmd) {
result = createEvent(zwaveEvent(cmd))
log.debug "Parse returned ${result?.descriptionText}"
return result
def sensorValueEvent(Short value) {
if (value) {
createEvent(name: "contact", value: "open", descriptionText: "$device.displayName is open")
} else {
createEvent(name: "contact", value: "closed", descriptionText: "$device.displayName is closed")
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
[name: "switch", value: cmd.value ? "on" : "off", type: "physical"]
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd)
sensorValueEvent(cmd.value)
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
[name: "switch", value: cmd.value ? "on" : "off", type: "digital"]
def zwaveEvent(physicalgraph.zwave.commands.sensorbinaryv1.SensorBinaryReport cmd)
sensorValueEvent(cmd.sensorValue)
def zwaveEvent(physicalgraph.zwave.commands.alarmv1.AlarmReport cmd)
sensorValueEvent(cmd.sensorState)
// Handles all Z-Wave commands we aren't interested in
def on() {
delayBetween([
zwave.basicV1.basicSet(value: 0xFF).format(),
zwave.switchBinaryV1.switchBinaryGet().format()
def off() {
delayBetween([
zwave.basicV1.basicSet(value: 0x00).format(),
def poll() {
def refresh() {
