I have a Toshiba air conditioner window unit that has wifi enabled. I can connect via the Toshiba app (Toshiba AC NA) but I would also like to integrate it into the smartthings app. Is that possible?
I don’t see Toshiba when I search for the brand.
I would like the toshiba ac to be in the smart things apps and it would be better if you would add other things to
At this point, smartthings has published their API, and it is up to the device manufacturers to create and maintain any integrations. So you should make your request of Toshiba and any other brands you are interested in. You can give them this link.
