You should contact LeGrand support, but I am pretty sure those two devices are not compatible regardless of the wall switch used. The physics are different.
A lighting dimmer works only for lighting, it works by changing the amount of current to the bulb. The current goes along the same pathway for all dim levels, there’s just more or less of it. Like turning up the heat on a gas stove.
A stepping switch is normally a uniselector relay motor control which transfers current along different physical pathways which then produce different motor behaviours.
But LeGrand support can tell you if a dimmer control will work with that stepper.
