I have had this lever for a while but never connected it to anything. There is a code to connect, but I don’t see the option in the ios app to add a device with a code, it just scans for them. My question is, how do I connect it? Thanks in advance!
Forgot to mention, this is what I have http://www.amazon.com/Schlage-FE599NX-CAM-619-ACC/dp/B0083GJ17G/
I have a different model Schlage, but here is what I did. You enter your programming code followed by 0 to enable the Z-Wave radio, then it auto joined the network (with the HUB in search mode)
Yours may be different, if you still have the manual it should have it in there.
Found the manual, it was like you said, except I needed to click the Schlage button before pressing 0, thanks!
No problem, glad you got it going.
