Ok, I’m a bit confused by the two different areas if the interface that are called the exact same thing. There are modes when you click the Hello Home button in the upper right and there are modes when you click the three line preferences in the upper left,
This is extremely confusing since it’s obvious they are not the same thing. They should really be called different things. Not good UI when two different objects are called the same.
What is the difference between them? I added a Party Mode in the upper left preferences, but that is not under hello home.
confused…
