I’m trying to port my hue dimmer switch DTH into LUA driver.
I’m stuck with porting this one.
zigbee.configureReporting(0xFC00, 0x0000, DataType.BITMAP8, 30, 30, null, [destEndpoint: 0x02])
[destEndpoint: 0x02] part is the problem.
It seems that there’s no way to set destEndpoint in class AttributeConfiguration
Attribute Configuration Documentation — SmartThings Edge Device Drivers documentation
Hue dimmer switch is a unusual device. Endpoint 1 is ZLL(=C05E), and Endpoint 2 is ZHA(=0104), and I need to configureReporting with ZHA endpoint. That’s why I need this endpoint option for configureReporting.
Could you help me with this?
Do I have to manually ZDO bind and do all the stuffs? or could it be automatically handled without specifying endpoint?
FYI, fingerprint of the device is as below.
"endpoints":[
"simple":"01 C05E 0820 02 01 0000 05 0000 0003 0004 0006 0008",
"application":"02",
"manufacturer":"Philips",
"model":"RWL020"
"simple":"02 0104 000C 00 05 0000 0001 0003 000F FC00 01 0019",
"application":"02",
"model":"RWL020"
Cluster 0xFC00 is in endpoint 2 only.
Can this be automatically handled by AttributeConfiguration class without specifying endpoint number?
